My Fiat Tipo HF Integrale
ICI
Post by ICI »
Hi to everyone.
I am so glad to introduce my project. Finally I did it.
This is actually Fiat Tipo Sedicivalvole turbo conversion.
It runs with Fiat Coupe 16VT ECU and chip by Ruben Aparici.
The expected power is 320 hp and max. boost 1,55 bar
Here is a little movie:
http://videos.streetfire.net/video/7abd ... 23905a.htm
The cams setting, according to this tread http://guy-croft.com/viewtopic.php?t=634
Picture 197.jpg (113.31 KiB) Viewed 63962 times
setting of TDC
setting of TDC
Picture 198.jpg (110.91 KiB) Viewed 63985 times
The head is ported slightly by my self, just to remove the imperfections from the casting.
Picture 133.jpg (120.23 KiB) Viewed 63996 times
Modified oil pick up holes.
Picture 138.jpg (87.6 KiB) Viewed 64006 times
My design cam wheels.The yellow part is aluminum, the gear part is made from original one.
Picture 141a.jpg (130.59 KiB) Viewed 64018 times
The pistons ready for build in together with con rods, lightened, shotpeened and balanced to 0,1 gram.
Picture 168.jpg (135.52 KiB) Viewed 64032 times
And the Solid model. We took from it the drawing for machining.
piston tuned.jpg (41.11 KiB) Viewed 64030 times
The pistons arrived without valve reliefs and also with smaller dish volume.I decided to machine them with maximum deep valve cuts and compression ratio 8:1. Together with Friend of mine we did a Solid Works model of the piston with desirable dish+valve c
Picture 001.jpg (130.04 KiB) Viewed 64055 times
The engine block is re bored to 84,5 mm because of the forged Iasa pistons.
Picture 092.jpg (119.68 KiB) Viewed 64048 times
3" air pipes
3" air pipes
Picture 022.jpg (125.64 KiB) Viewed 63873 times
K&N filter
K&N filter
Picture 020.jpg (134.48 KiB) Viewed 63888 times
3" downpipe
3" downpipe
Picture 019.jpg (106.91 KiB) Viewed 63894 times
Picture 018.jpg (96.27 KiB) Viewed 63901 times
Garrett GT2860RS with T3 flange and external wastegate Turbosmart 38 mm. Cooler dimensions are 600 x 300 x 70 mm
Picture 004.jpg (95.79 KiB) Viewed 63912 times
Bosch - Ford Motorsport 420 cc / 3 bar , actually they are up to 490 cc
Picture 068.jpg (118.58 KiB) Viewed 63923 times
Cometic MLS gasket 1,9 mm. Actually it is 2,2 mm compressed, becorse of the reliefs
Picture 055.jpg (155.09 KiB) Viewed 63922 times
the sump http://guy-croft.com/viewtopic.php?t=842
Picture 188.jpg (133.24 KiB) Viewed 63933 times
Adventure cars - Italy clutch
Picture 002.jpg (120.18 KiB) Viewed 63949 times
the flywheel not yet painted http://guy-croft.com/viewtopic.php?t=607
Picture 130.jpg (88.69 KiB) Viewed 63951 times
powered by ICIDesign
SteveNZ
Post by SteveNZ »
Nice work, Any pictures of the car?
ICI
Post by ICI »
SteveNZ wrote:Nice work, Any pictures of the car?
Yes, I add a little movie of the beginning of the post - the link.
ICI
Post by ICI »
beautiful finish of the track day
Picture 028.jpg (85.59 KiB) Viewed 63805 times
Iliyan, hi
great project, nicely presented too - well done indeed!
SteveNZ
Post by SteveNZ »
Hi
How have you mounted the wastegate? Is it welded straight onto the original wastegate hole?
ICI
Post by ICI »
Thank You for the nice words, gents.
The wastegate is welded to the turbo exhaust flange via short S pipe, just to suit the place.
Here is detailed pictures of the flanges and the hole in the turbo housing.
For the future time I will go for tubular exhaust collector and the wastegate pipe will come out directly from it, just right before it's T3 flange.
Iliyan
Picture 205 copy.jpg (239 KiB) Viewed 63723 times
Picture 006 copy.jpg (175.55 KiB) Viewed 63729 times
bob
Post by bob »
Hi CIC , I need you help , I want to put a turbo at my sedici too , I like to know what exactly parts have you used in your project !
If you remenber the web sites it‚´s going to be great!
thanks
BoB - Brasil !
ICI
Post by ICI »
Hi bob, everything I used in my car is showed in the pictures, nothing hidden there.
ICI
Re: My Turbo Tipo
Post by ICI »
Little update :)
Tubular manifold made by me. SS 304L 38mm ID equal lenght, about 600mm lenght of each runner. It is stick welded, not TIG unfortunately, but looks fine after few hundreds km
Picture 011.jpg (433.22 KiB) Viewed 61941 times
Picture 012.jpg (426.19 KiB) Viewed 61925 times
Picture 017 HDR 0.jpg (445.61 KiB) Viewed 61911 times
wraped with ceramic fabrik
Picture 030.jpg (207.29 KiB) Viewed 61880 times
Picture 064.jpg (335.07 KiB) Viewed 61878 times
Picture 065.jpg (274.62 KiB) Viewed 61862 times
ECU emulator for maping
Picture 058.jpg (354 KiB) Viewed 61866 times
Picture 073.jpg (319.51 KiB) Viewed 61834 times
ICI
Re: My Turbo Tipo
Post by ICI »
NickRP
Re: My Turbo Tipo
Post by NickRP »
ICI,
Excellent project, I do like it a lot.
How satisfied are you with the spool-up time? I expect it to be fine with GT2860RS. I assume you are not using antilag?
Do you still use Pierburg valve for regulating boost? Did you have to change integral boost valve duty cycle correction terms in the map to suit quicker response times of GT2860RS in comparison to OEM turbocharger? If not, are you experiencing boost overshots?
A friend of mine and I did a similar conversion a couple of years ago. However, we used T3 in Super 60 trim, which generated boost quite high in the RPM range. This was partly sorted out by exhaust cam timing and antilag. We used stock Tipo 2.0 16v 5 door cams, but later resorted to Thema turbo exhaust cam, which helped quite a bit.
Which cams do you use and how are they timed (degrees between peak lift and TDC)?
If possible, I would highly appreciate if you could post a log of your measured boost level vs. RPM in 4th or 5th gear.
Keep up the good work,
Nikola
ICI
Re: My Turbo Tipo
Post by ICI »
Hi Nikola
I know yours turbo Tipo project long time ago, still when it was presented in http://www.hollosites. It was kind of a guiding line for me :)If you mentioned the red one Cosworth in the video - it is running with your RP lab ECU at 1bar at this moment, waiting mapping for 2bar.
Now on the questions.
The car is amazingly responsive with this turbo.
No antilag system, over 3000rpm every blip on the throttle make difference.
Yes, it is with standard Pierburg boost solenoid valve, but is using external wastegate with 0,8bar spring.
About duty cycle, I can't see is there is any difference with the stock bin, because I did't have proper .xdf with this table for TunerPro.The boost spikes not more than 1,2 bar.
But there is a problem with clutch slipping on 4th and 5th gear, which reflects on the boost rise.
Here is all about my cams and timing :
I will post logs, if I could make them these days.
I am confused a bit because I bought Innovate RPM converter to collect 5 sensor signals for logging, but it seems probably it can work only connected with Innovate LM-1, which transfers data to laptop.I was told that RPM converter can be connected via serial stereo cable with my Innovate LC-1 wide band, and from there to laptop for logging.I have to try this.
At this moment I am watching only AFR.
Iliyan
NickRP
Re: My Turbo Tipo
Post by NickRP »
Hello Iliyan,
Thanks for the link on cams timing, sorry that I missed it initially.
Unfortunately, I haven't had any experiences with Innovate products, so I can't really assist you on how to make use of the RPM converter with LC-1. I do the logging in "traditional way", through the ECU connected to laptop.
As for clutch slip problem that you mentioned, we had the same with Tipo 16v OEM 215mm clutch. It proved more cost effective to go for OEM 230mm item (including Dedra Turbo cable actuated gearbox) than uprated 215mm clutch. This solved the slipping issue completely.
Does your modified chip have duty cycle table on the same location as OEM? Maybe I am wrong, but I thought there was a freeware XDF for OEM coupe 16vt chip? It was of moderate quality, but at least such basic things like boost duty cycle table were interpreted correctly. I was actually asking about duty cycle integral correction tables, as those are a bit tricky to adjust (many tuners don't have idea that they exist, nevertheless they are playing a key role in reaching boost setpoint quickly and avoiding overshots).
Please send my regards to Martin!
Ciao,
Nikola
P.S. Watch out for cracks that may develop on the exhaust header.
ICI
Re: My Turbo Tipo
Post by ICI »
NickRP wrote: I do the logging in "traditional way", through the ECU connected to laptop.
Hi NIkola, would you tell me is it possible to do logging with the stock Fiat Coupe ECU and how ?
NickRP wrote:As for clutch slip problem that you mentioned, we had the same with Tipo 16v OEM 215mm clutch. It proved more cost effective to go for OEM 230mm item (including Dedra Turbo cable actuated gearbox) than uprated 215mm clutch. This solved the slipping issue completely.
In my case the problem is very unpleasant, because I use ceramic clutch with 30% uprated pressure plate 228mm push type.You can see it on the pictures above.
I hope this is due to still incomplete bed in.
NickRP wrote:Does your modified chip have duty cycle table on the same location as OEM? Maybe I am wrong, but I thought there was a freeware XDF for OEM coupe 16vt chip? It was of moderate quality, but at least such basic things like boost duty cycle table were interpreted correctly. I was actually asking about duty cycle integral correction tables, as those are a bit tricky to adjust (many tuners don't have idea that they exist, nevertheless they are playing a key role in reaching boost setpoint quickly and avoiding overshots).
Yes, you are right.There is newer version of .xdf, which I did't use before.
This is what it shows.
I also add the boost level table to see.
Ciao,
Iliyan
Untitled-2 copy.jpg (94.24 KiB) Viewed 61779 times
Untitled-3 copy.jpg (75.94 KiB) Viewed 61770 times
