1608 big valve engine carburetion
vcg
Post by vcg »
I just finished a big valve convertion for my 1608 BS1. Compression is 10.5:1, inlet valve 43.5 outlet 38, and the cam is Kent FT10. I am trying to make it work with 40IDFs, but all I get is very torquy curve from 2000-5000rpm and not a very good top end with 4th and 5th gear. I am working the 40IDFs with F11 emultions, is that ok you think? Or would F9 be better?
Could you please suggest a jetting for 40IDFs?
Vassilis
I'd need more data to be able to comment usefully, eg:
- choke size and main/ air corrector jets currently fitted
- mixture (CO or Lambda) thru range 4000+ as it is at present. If you haven't checked this you cannot pin the problem on jetting...
- ex header details (4-2-1/4-1 and dimensions)
- silencer type
- air filter setup
- cam timing
- fuel pump type/pressure
- head state (fully flowed etc)
Obviously things like carb balance and ignition timing have a bearing on this too.
Photos of engine/car would be nice too, adds interest to GC Q&A .. as I keep saying..
vcg
Post by vcg »
Ok, this is the case:
I preperared this head originally for my 124 BC1 Coupe racer. However since the car worked so good, I decided not to touch it, so I fitted it on the Spider.
The Spider set up now is as such:
Fully flowed ported head 43.5 inlet, 38.5 outlet
4-2-1 Header 38-42-50mm respectively, single see through 60mm silencer
Kent FT 10 282deg, 10.35 lift, 70 overlap
40IDF 34 venturi, 60 idle, 160 main, 180 air, F11 emulsion
The car is a TORQUE BEAST up to 6500rpm, and it continues at lesser pace up to 7200rpm. This is different from what I expected. I was expecting a pretty shallow bottom and a unacceptable top up to 8000rpm, but I guess the fact that I used a mild cam is the reason. I was afraid to use higher than 2.8-3.0 mm lift at TDC cam due to the large valve sizes and the small piston diameter (80mm) and the small carb available (40IDF).
There are two issues that puzzle me:
(1) WIll I gain at the top if I increase overlap-TDC lift with present cams and with present carbs? Or is is it a case of undercarbed setup that the top is at it's limit?
(2) This kind of 40IDF jetting (160 main with 34 chokes) I have seen only in VWs, never in a TC before. Is it because of the valve sizes?
PS: photos will follow
Thanks Guy,
Vassilis
vcg
Post by vcg »
Mystery solved!: Sticky pin in one of the floats...
Jetting is as such for big valve 1608cc Fiat TC with a mild cam:
Weber 40IDF 13-15 with 35mm horns & no filters
34 chokes
F11 emulsions
60 idles
145 mains
200 airs
pumps 40
The car works really nice, it pulls strong from 2000rpm up to 8000rpm - no flat spots. Max torque around 5200rpm, max hp around 7300rpm, estimated around 140bhp at the flywheel.
Sorry for the confusion Guy,
Vassilis
Vassilis, hi
that's great! You got the solution before I could even assess the setup. Sorry but I have been pretty tied up at work and a bit slower than usual with a bad back.
Well done and thanks for telling me quickly!
