Hi Guy.
Do you know if the Tipo 16v clutch will fit on the Tipo 2.0 8v? Basically the same gearbox, so iam assuming just a stronger clamping clutch?
Andy.
Tipo 2.0 8v clutch
Andy, hi
because of the risk of their not being the same (and this is true of other motors too) and I just don't know - I never engage in shop & swap with clutches. The FL TC 8V and 16v range is so huge that I know of plenty of folks getting in real difficulties with this, some are members here too.
Run with the OE fw for your motor and get a comp clutch from Helix in Banbury. I'm an agent FWIW but I insist on pattern cover and plate to travel there with order to be absolutely sure.
