Plastic cam pulleys
Daniel
Plastic cam pulleys
Post by Daniel »
Mr. Croft.
I found old stocks of plastic cam pulleys that there OEM parts for the 132/2000 engine and i have some doubtd to use it in my race 1608 engine. hat do you think?
Sincerely,
Daniel
Andy007
Plastic cam pulleys
Post by Andy007 »
in a race engine you need adjustable cam wheels. It is impossible to adjust the cams exactly with the O.E. pulleys ....
Greets Andy007
tmvolumex
Plastic cam pulleys
Post by tmvolumex »
The plastic pulleys are junk. The steel center on the plastic pulleys gets loose and it sounds like a rod knock. When the steel center is loose the cam timing varies and the timing belt does not run true. Use metal pulleys.
Tom McGaffigan
