Hello Guy/all,
Do you always knife edge the divider between the inlet ports on a 16v head? Or are there any instances where you wouldn't do this and just leave a smooth radiused edge? How much in the way of gains (if any) are there to be made from this mod or is it just a case of splitting the air cleanly and evenly?
Martin.
Knife edging 16v port divider
That section, which I call the splitter, varies in shape from head to head - some like Integrale and Vauxhall XE have a long splitter, dividing the airstream almost at entry, while others like Toyota 16v are very short.
On the longer ones the gain in knife-edging varies from 2-3 cfm to way more than that, but the best gains come only with full reshaping and sometimes shortening (not always at top and bottom), because simply putting a blade-like form on the nose of the splitter can result in an aerofoil 'hump' on the splitter further into the port, so you see there's a lot more involved than just sharpening the thing.
- Toyota 16v 1600 head showing short splitter compared with Integrale
- PC Toyota 16v sidedraft port after flowing.jpg (23.84 KiB) Viewed 6672 times
- GC Integrale head upside down showing fully developed splitter on a head flowing BPF 162.3cfm at 10".
- MM Int inlet guide intrusion.jpg (452.07 KiB) Viewed 6672 times
