Fiat Uno 1.6 By Bax & Dodo
fiatuno
Post by fiatuno »
Hi All
Proud Owners Bax & Dodo prezents
Fiat Uno CS 1991
Prepared By Zlobin Bax & Dodo TEAM
with some help of quartermile team
In the begining
Now
Engine block
Lancia 1.5 SOHC, modified to 1.6
Bore 86,4mm
Stroke 67,4mm
Pistons from Fiat Tipo 1.6
Crankshaft from Fiat Tipo 1.6
Comp Ratio 13.4:1
Head & valve
Inlet valve 40mm
Exhaust valve 36mm
32mm canal Ports
Custom Camshaft 300‚°
Competition valve springs
Intake
Engine is normal aspirated with 4 Dellorto carbs
4x40 Dellorto DHLA with 8liter air box
Carburetors are modified:
Choke sizes 36
Main jets 150
Emulsion tubes 7772.7 modified
Air correctors 180
Cold Air intake
Fuel delywery by electronic pump with Malpasi preasure regulator
Exhaust
Custom exhaust manifold four pipes fi35 in one pipe fi60
Extreem flow muffler 60-90-60
Gearbox & Clutch
Flywheel lightened from Lancia 1.3 aproximatly 3kg
Clutch- 3 pastille Ceramics, without springs. Sinter
Gear box- 4 speeds diff.ratio13/53 from Fiat 128 Sport
Fuel tank
From a boat app. 20lit
Suspension
Adjustable Koni sport with 60kg Eibach springs
Brakes
Uno turbo, 4 disc with Ceramic pads
Wheels
Aluminium 7x13
Tires
Fulda 175/50 R13
Poliester Hoods
Best time on quartermile
14,8s with 0,6s reaction time
Batery in the trunk
Engine Place
Pictures from Inside
Picture From races
Best Regards
Robert & Dorian
Zlobin Team
Der’‚³
Post by Der’‚³ »
Robert & Dorian,
Congratulations for yours superb car.
