I have bought a Hoermann Rallye Camshaft.
The data's:
Inlet 11,3mm - Exhaust 8,3mm Lift
Inlet 26‚°/66‚° - Exhaust 67‚°/41‚°
Today I have written the lift on paper every 2,5‚°.
But here must be some wrong because the Inlet valve (German "Einlass") closes when the exhaust valve opens...
Do I have a wrong deg pulley?
I have add a picture how I have measured it.
I know that my degree's are wrong because I must add 180‚°.
I had fitted the standard cambelt pulley from the 1.3 turbo and I had set the tdc of the degree pulley on the mark of the tdc (to know if the standard pulley is right) but I had fitted the gauge on the wrong site (about the camshaft and not under like in the engine it is... I hope you understand!).
Thanks for helping.
The main problem is, Hoermann doesn't have a data's for the camshaft and I need the lift in tdc to install this cam :(
Before asking, Yes I know what it means to drive this camshaft. It's rallye camshaft from Italy. Maybe a "Group" camshaft...
camshaft - how to find lift in tdc?
Acki
- Bild223.jpg (59.69 KiB) Viewed 6436 times
- Excel screenshot
- nockenwelle.JPG (90.84 KiB) Viewed 6436 times
Acki
Acki
Just for a check Acki
(All figures are crank degrees (twice cam deg))
Inlet duration is 272 deg
Ex duration is 288 deg
Overlap period is (26 + 41) = 67 deg
Inlet full lift is 110 deg ATDC
Ex full lift is 103 deg BTDC
Lobe centreline angle 213 deg
In case you don't know - you need to degree-map these cams with a bucket (flat follower) in a cam housing, not with the dti gauge straight on the cam profile. The timing figures you gave (from the maker) depend on the clearance they are measured at - could be anything from zero (with flat follower) to 0.5mm. If you don't know that clearance figure you cannot compare the timing figures with the ones you measured. If you measure with zero clearance & the manufacturer used 0.4 inlet and 0.45mm ex (for example) your durations are going to look much longer than his.
Acki
Thanks Guy.
The clearance is 0,3 inlet and 0,35 exhaust :)
I have set the tdc ~13‚° after the inlet begins to open (in this point the lift is 0,31mm at 347,5‚° and so that are 12,5‚°).
I think I must test a little bit with the camshaft (1,2,3‚° before and after the point I have found now).
But I need this curve for making my pistons for the valve "pockets" (?) and there is a little safty... maybe you can help me?
After the curve the lift in tdc is 1,29mm - 0,30mm = 0,99mm.
I think 1mm is correct.
I hope my englisch is not too bad :(
- correct curve
- nockenwelle3.JPG (108.14 KiB) Viewed 6414 times
