Integrale head on a 1919 TC motor.
cheitane2003
Post by cheitane2003 »
Hallo Guy:
I need to raise the CR on order to obtein the best from the cams. Should I found any problem changing the 1585 head in first photo installing an Integrale turbo ones?
As you can see the chambers in the Integrale are not so big than in the other.
Thank you very much.
Integrale head with number 7676150
1585 cc head
1585 cc head
Problems:
You do realise that the valve layout is reversed?
I mean the Integrale inlets are on the other side of the head compared with the early TC. So this head will not work with the early pistons, the vr's are wrong - although they could be machined.
cheitane2003
Guy:
Thank you very much, I couldn‚´t see it clear on these photos.
