a lot of stuff lost that I uploaded of late due to the problems caused by 123-reg who deleted our website in its entirety..
thanks to QA Webhosting we have backup. Up to what point I am not entirely sure. What I do know is that Phil at QA has been hosting and running sites for 20 years and 3 of mine for 8 or more and this is the worst possible scenario for him and I am avoiding bothering more than I have to..
If you have a post with missing pics please EMAIL ME!
guy.croft@btconnect.com
GC engines 2014-2016 - 1600 Duratec race unit - phase 1
- IMG_9263.JPG (143.12 KiB) Viewed 78249 times
- IMG_9264.JPG (139.95 KiB) Viewed 78249 times
- IMG_9265.JPG (136.13 KiB) Viewed 78249 times
- IMG_9266.JPG (113.67 KiB) Viewed 78249 times
- IMG_9267.JPG (137.15 KiB) Viewed 78249 times
- IMG_9273.JPG (143.01 KiB) Viewed 78249 times
- IMG_9274.JPG (143.92 KiB) Viewed 78249 times
- IMG_9430.JPG (174.01 KiB) Viewed 78249 times
- IMG_9431.JPG (169.29 KiB) Viewed 78249 times
- IMG_9432.JPG (156.34 KiB) Viewed 78249 times
- IMG_9549.JPG (78.4 KiB) Viewed 78249 times
- TN Duratec deburr & preclean block (1).JPG (121.3 KiB) Viewed 78249 times
- TN Duratec deburr & preclean block (2).JPG (120.25 KiB) Viewed 78249 times
- TN Duratec deburr & preclean block (3).JPG (132.03 KiB) Viewed 78249 times
- TN Duratec deburr & preclean block (4).JPG (140.87 KiB) Viewed 78249 times
- TN Duratec deburr & preclean block (5).JPG (136.17 KiB) Viewed 78249 times
- TN Duratec deburr & preclean block (6).JPG (135.64 KiB) Viewed 78249 times
- TN Duratec deburr & preclean block (7).JPG (133.27 KiB) Viewed 78249 times
- TN Duratec deburr & preclean block.JPG (136.33 KiB) Viewed 78249 times
- TN Duratec survey block face (8).JPG (117.34 KiB) Viewed 78249 times
- TN Duratec X test block (9).JPG (152.83 KiB) Viewed 78249 times
- TN Duratec X test block (10).JPG (133.92 KiB) Viewed 78249 times
- TN Duratec X test FW (11).JPG (173.08 KiB) Viewed 78249 times
- TN Duratec_ (14).JPG (746.23 KiB) Viewed 78249 times
- TN Duratec_ (15).JPG (561.8 KiB) Viewed 78249 times
- TN Duratec_ block post reface deburr (1).JPG (119.44 KiB) Viewed 78249 times
- TN Duratec_ block post reface deburr.JPG (119.7 KiB) Viewed 78249 times
- TN Duratec_ head post reface deburr ops all over (1).JPG (123.47 KiB) Viewed 78249 times
- TN Duratec_ head post reface deburr ops all over (2).JPG (116.59 KiB) Viewed 78249 times
- TN Duratec_ head post reface deburr ops all over (3).JPG (121.19 KiB) Viewed 78249 times
- TN Duratec_ head post reface deburr ops all over.JPG (124.67 KiB) Viewed 78249 times
- TN Duratec_ microhoning at 180 silicon carbide for chrome-faced Ford rings (1).JPG (134.8 KiB) Viewed 78249 times
- TN Duratec_ microhoning at 180 silicon carbide for chrome-faced Ford rings (2).JPG (136.92 KiB) Viewed 78249 times
- TN Duratec_ microhoning at 180 silicon carbide for chrome-faced Ford rings (3).JPG (147.71 KiB) Viewed 78249 times
- TN Duratec_ microhoning at 180 silicon carbide for chrome-faced Ford rings.JPG (137.15 KiB) Viewed 78249 times
- TN Duratec_ washing head prior to seat light grind.JPG (162.21 KiB) Viewed 78249 times
- TN Duratec_block face & bores X test (1).JPG (104.15 KiB) Viewed 78249 times
- TN Duratec_block face & bores X test (2).JPG (125.58 KiB) Viewed 78249 times
- TN Duratec_block face & bores X test (3).JPG (141.25 KiB) Viewed 78249 times
- TN Duratec_block face & bores X test.JPG (114.88 KiB) Viewed 78249 times
- TN Duratec_block post reface.JPG (128.91 KiB) Viewed 78249 times
- TN Duratec_checking crank runout (1).JPG (132.02 KiB) Viewed 78249 times
- TN Duratec_checking crank runout.JPG (134.58 KiB) Viewed 78249 times
- TN Duratec_ex seat after.JPG (129.44 KiB) Viewed 78249 times
- TN Duratec_ex seat before.JPG (125.43 KiB) Viewed 78249 times
- TN Duratec_ex seat leak testing.JPG (136.59 KiB) Viewed 78249 times
- TN Duratec_final dress of top face.JPG (154.46 KiB) Viewed 78249 times
- TN Duratec_final hot detergent wash block (1).JPG (110.74 KiB) Viewed 78249 times
- TN Duratec_final hot detergent wash block.JPG (132.72 KiB) Viewed 78249 times
- TN Duratec_final hot wash per-build. Smearing vanishes after wipe with WD40...JPG (136.99 KiB) Viewed 78249 times
- TN Duratec_finished seats post lap closeup.JPG (117.63 KiB) Viewed 78249 times
- TN Duratec_head (raw) post press test & reface 5thou.JPG (150.08 KiB) Viewed 78249 times
- TN Duratec_in valve seat grinding (1).JPG (130.65 KiB) Viewed 78249 times
- TN Duratec_in valve seat grinding (2).JPG (139.2 KiB) Viewed 78249 times
- TN Duratec_in valve seat grinding (3).JPG (146.43 KiB) Viewed 78249 times
- TN Duratec_in valve seat grinding (4).JPG (134.14 KiB) Viewed 78249 times
- TN Duratec_in valve seat grinding (5).JPG (125.32 KiB) Viewed 78249 times
- TN Duratec_in valve seat grinding (6).JPG (135.71 KiB) Viewed 78249 times
- TN Duratec_in valve seat grinding (7).JPG (122.74 KiB) Viewed 78249 times
- TN Duratec_in valve seat grinding (8).JPG (115.31 KiB) Viewed 78249 times
- TN Duratec_in valve seat grinding.JPG (127.06 KiB) Viewed 78249 times
- TN Duratec_strip (1).JPG (100.54 KiB) Viewed 78249 times
- TN Duratec_strip (2).JPG (112.97 KiB) Viewed 78249 times
- TN Duratec_strip (3).JPG (102.97 KiB) Viewed 78249 times
- TN Duratec_strip (4).JPG (97.18 KiB) Viewed 78249 times
- TN Duratec_strip (5).JPG (120.45 KiB) Viewed 78249 times
- TN Duratec_strip (6).JPG (130.21 KiB) Viewed 78249 times
- TN Duratec_strip (7).JPG (145.88 KiB) Viewed 78249 times
- TN Duratec_strip (8).JPG (148.6 KiB) Viewed 78249 times
- TN Duratec_strip (9).JPG (148.65 KiB) Viewed 78249 times
- TN Duratec_strip (10).JPG (127.87 KiB) Viewed 78249 times
- TN Duratec_strip (11).JPG (125.22 KiB) Viewed 78249 times
- TN Duratec_strip (12).JPG (104.54 KiB) Viewed 78249 times
- TN Duratec_strip (13).JPG (124.94 KiB) Viewed 78249 times
- TN Duratec_strip (14).JPG (140.22 KiB) Viewed 78249 times
- TN Duratec_strip (15).JPG (112.84 KiB) Viewed 78249 times
- TN Duratec_strip.JPG (117.95 KiB) Viewed 78249 times
- TN Duratec_valves X test (1).JPG (125.75 KiB) Viewed 78249 times
- TN Duratec_valves X test after beadblast.JPG (151.22 KiB) Viewed 78249 times
- TN Duratec_valves X test.JPG (82.45 KiB) Viewed 78249 times
- TN FW runout overlimit.JPG (137.63 KiB) Viewed 78249 times
- TN FW X test OK.JPG (131.77 KiB) Viewed 78249 times
