Few words about OE TC sodium cooled exhaust valves.
Post by Piotrek125p »
Hi.
Last week I stripped an 8v Integrale head. Fortunately, the OE exhaust sodium cooled valves were fitted in this head. I thought that it is good time to make a thread here to help members how to recognize Fiat TC sodium cooled valves.
First thing, solid exhaust valves has a waisted stem, sodium hasn't, I think that this photo is a good example, look at a marked place
Second thing, in my opinion sodium valves has more thick valve heads (margin in my dictionary), see attached photo.
Third thing, some of these valves has A362 mark on top with Fiat logo.
This is in my opinion main differences between solid and sodium Fiat TC exhaust valves. I know that attached by me photos isn't world class, I made it with my mobile phone, if someone need a better photos I will try to make it with a professional camera.
Fill free to discuss here about this type of valves, maybe you, members, spotted more differences or simple want to talk about.
Sincerely.
Piotrek.
Re: Few words about OE TC sodium cooled exhaust valves.
Piotr
you are right, good thread, the non-waisted stem is the sign,
sodium-cooled exhaust valves are a 'must-have' for supercharged and turbocharged applications. They have no equal.
FiatRally
Post by FiatRally »
People always moan to me that I am to technical and mathematical. So here I would like to add a bit of what makes me a Fiat Twin Cam fan.
Years ago Toyota launched the first RSI cars in South Africa. My father being a Petrol / Diesel Mechanic, that was also working in the Engineering field had something to say to their ads! He was a Fiat TC fan his whole life.
The ads pushed: Twin Cam, 16 Valve, Sodium Cooled Exhaust Valves
So when a Toyota Salesman was chatting about this "new" development in automotive engineering, my father asked him: Please tell me what is new to these engines?
The Salesman looked at my father as if he was an idiot and said: Don't you understand the technology that has gone into these "new" designed engines?
My father asked him the same question probably 2 more times, then gave him a mouth full that I will not repeat here.
And calmly in front of all the people present told him that Fiat has done it in the 60s already!
I don't know if Fiat was the first to run Sodium filled exhaust valves but they did use that technology very successfully over the years.
When I think of Twin Cams I always think of that day!
GC_75
Today I done some inspect op to my sodium cooled valves. A set from OE Delta Turbo (OE springs, OE cams) had a not good looking valve contact damage.
20160428_162318 (1024x576).jpg (163.56 KiB) Viewed 137961 times
It is a typical issue with this type of valves according to very narrow sealing surface ? Valve stems and tips are in excellent condition, only valve head are heavy polluted with carbon deposits.
If I will reface it in a valve grinding machine (they had a really thick valve margin) can I use it or it is a scrap ?
Sincerely Piotrek.
GC, could you write a few words about valve from photo that I attached, please ?
I would have a go at regrinding them, they will probably clean up. That op wil drop the valves deeper into the head, you should measure the tip setup height (VSH) which is 40.5 - 40.7mm from tip to spring platform in standard spec, you can grind the tips down but always leave at least 1mm of stem above the collet groove. If you are using comp cams that extra height can help with shimming. The other way to cope with a tall VSH is to use two cambox gaskets but you'll definitely need adjustable camwheels then..
The old ex valves were probably stellite coated and likely that will get ground off, but underneath is austenitic 21-4n stainless steel which is an excellent valve material in its own right - so don't worry about it.
They will go for head with IIB ex cam with a new seats, I will measure all and decide how much tall seat should be.
Thanks for your information, this is very helpful. I was going to do the same, it is really nice that you confirm my decision.
glad to help Piotr
