Straight-cut competition gearbox - Lancia Beta or Montecarlo
Snakeman
Post by Snakeman »
Hi All,
I have been circuit racing my Lancia Montecarlo for a few years now where I am at the stage of looking to upgrade my transmission from and OE box to an Involute straight cut gear set with dog engagement, preferably also with straight cut final drive gear.
The eliminated shaft thrust from helical gears and helical final drive can only serve to provide my torque to the road wheels. I am also hoping it survive longer than the syncro box's I've used
I am aware of a gear & shaft conversion in Italy (Kit RCE15 by Bacciromano or Carenini), but this particular kit seems to retain the syncromesh engagement. I am also aware that Cololli also offer a kit - T.171
Has anyone ordered any of these gear kits and successfully installed them? I am slightly nervous of ordering these items direct from Italy because there will inevitably be questions about bearings used, installation guidance etc. and my Italian speaking is limited to beer and coffee purchasing (!)
Alternatively, and my much preferred option, has anyone commissioned a UK company to manufacture a straight cut gear-set for a Lancia Beta or Montecarlo?
Geoff W
Re: Straight-cut competition gearbox - Lancia Beta or Montec
You're right to be circumspect about this Geoff.
Years and years ago John Day raced with a Colotti box he'd built and it never misbehaved. Paul Brace got a set for his MC and it slipped out of mesh over and over and never ran right.
If I were you I would talk to Quaife
http://quaife.co.uk/shop/search/results ... 619?page=2
I'd ask them the nearest equivalent non-Lancia transverse box they have and see if it can be adapted. This may seem a frightening proposition!
It may be that they can buy in Italian stuff and build it up. I would not be surprised if they can.
Member Rich Ellingham (that is his username) has a Bacci gearset in his Tipo, he may be able to help here. He is always very helpful - pm him.
Post by Will01 »
If it is the same John Day which i suspect it is, he works for Days & Whites garages in Kent round the back of Brands Hatch. John is a really nice chap and we have had discussions in the past including some of his racing. They are Alfa Fiat Lancia specialists in the south east and i wouldn't be surprised if they could help you with orders from Italy as they order many of their spares from there.
Pretty sure they were building up a MC a few years back for racing, but i may be mistaken.
I have used them for parts and servicing in the past and they are highly recommended from me.
Yes that is John
Snakeman
Post by Snakeman »
Following email correspondence with Quaife, they will only do a gear kit for a minimum quantity of 30 units, so that's a non-starter.
Stay tuned...
tmvolumex
Post by tmvolumex »
In your post you mentioned
"The eliminated shaft thrust from helical gears and helical final drive can only serve to provide my torque to the road wheels."
This is true but:
The final drive is subjected to the most torque and thus would generate the most power loss with anything but straight cut final drive gears.
Your Monte has essentially straight cut final drive gears in the final drive now. I say essentially as they are cut at a slight angle to reduce gear noise as in done in FWD cars.
On a rolling road dyno the correction factor for CRANK BHP vs rear wheel BHP is quite a bit different for FWD cars vs RWD cars.The reason is, most FWD cars use essentially a straight cut ring and pinion final drive gears (as in your Monte) versus a 90 degree hypoid gear set up in a front engine RWD car. A ring and pinion with all gears turning one plane (all in one plane) has a much higher efficiency than a hypoid (90 degree) set up. I would doubt if the reduction is losses, thus more power to the rear wheels, by going to a straight cut gear tooth set up, would be worth the expense. RWD losses are 15 - 20 % because of the hypoid final drive. FWD and transverse RWD is maybe 5%
Usually straight cut gears are used in a gear boxes because they are stronger and can accommodate a dog mesh system which allows additional gear width, created by eliminating the syncromesh. Dog mesh gear boxes can be shifted without the clutch, much faster than a syncromesh box if you are skilled and dont mind higher maintenance.
GC_31
the att dyno curve of Geoff's (with respect) shows the actual loss on his MC...
it's a lot more than 5% and not linear..
Goeff Ward dyno data.jpg (289.05 KiB) Viewed 154223 times
tmvolumex
Post by tmvolumex »
I believe that most chassis dyno shops do not change the correction factor for different final drive types in the car they test on a chassis dyno. The correction factor usually set in the software program is for a hypoid final drive, not a spur gear set up like the Monte has.
GC_31
tmvolumex
Post by tmvolumex »
The only way to determine actual drive train loss would be to compare engine dyno test data with a chassis dyno test data.
On the other hand, when it is all said and done, it is the power and torque to the rear wheels (or front wheels, or all 4 wheels) that is the important factor.
GC_31
sorry Tom, Geoff's FW figures of torque and power from Northampton Motorsport rr correlate exactly with my own bench dyno data and have every time someone with one of my engines has gone there - to within a few bhp, which is why I recommend them almost exclusively.
Beyond that I am not really qualified to add anything useful (assuming that was...!)..
