-Oil and water: ok
-no apparent cracks on the back of the block, close to the core plugs
-no apparent coolant leak; other than a few minuscule water bubbles on the expansion tank, below the water level, attached to the walls
-didn't smelled nothing burned with heat
-spark plugs are ok
Drove the car for 20 minutes and it all seemed fine with the temperature, going no further than 90º at idle, and lowering while cruising at low/moderate speeds to 70/73º +/-. After driving the car, i left it idling for 5+ minutes, and the water temperature was always stable at close to 90º, with the fan switching on multiple times. (As before). It seems ok, but i am afraid there will be mid/long term consequences might be.
Any help or tips will be appreciated.
Edit #1: a few hours after doing all that indicated above, i opened the expansion tank, started the car and left it idle. The minuscule air bubbles are still there, and the car warms up normally till the correct temperature, but if i give it a little go on the throttle there are lots of bubbles on the tank. The water level raises a just a little bit but doesn't spill out of the tank in any way. There is also a bit of water on the tailpipe and the weather is still warm...
engine specs :
Lancia dedra sohc 1.6 | uno turbo exhaust valves
Headgasket: spesso racing 1.9mm
scat forged rods
wossner forged pistons
arp head studs
There were two white lines remaining on the temp gauge when it overheated...
