Supercharged x/9 1300
Charlie
Hi
Here is a picture of my supercharged Fiat x1/9 1300
Charlie.
Charlie.
- Supercharged Fiat x1/9 1300
- Supercharger.gif (49.21 KiB) Viewed 24499 times
James Bowen
Charlie
The car will now happily redline in fourth gear , but I am using a knock sensing ignition retard unit with a 6500rpm rev limiter at the moment.
The compression ratio has been reduced to 8:1 by fitting a 1500 cylinder head. I am currently fitting an oil cooler and a freeflow exhaust and I need to change my final drive ratio to make the most of the torque now available. The car is currently running about 7 psi of boost and I don,t want to play about with that side until these mods have been made.
Charlie
Charlie
Charlie
As a matter of interest which Fiat / Lancia models used the 1.5 MPI engine.
I know that a fuel injected version of the 1500 x1/9 was sold in the USA,
but I have not seen any 1.5 MPI engined cars here in Ireland.
8.8 : 1 compression ratio may be a bit high without intercooling for a roots type blower set up.
Charlie.
Charlie.
Charlie
Charlie
Julian
Guy - that is just the throttle linkage unless I've totally misunderstood what you are referring to. The cable running direct to the carburettor is actually the choke. The X1/9 throttle runs up the front of the engine with a linkage transferring the action to the #1 end. There is a bell transferring the motion from fore-aft to side-to-side. The "spindle" is the linkage operating the throttle...
Charlie
Julian has it all sussed out correctly. Throttle motion is converted to push rod operation from the bell crank to the butterfly spindle. It allowed me to use the existing throttle cable set up. By using a side draught twin choke carb it leaves the option of bolting on a Jenvy throttle body if I want to convert to EFI at a later stage. Guy actually helped me with setting up the carb reguarding choke sizes, jets ect. Its currently using 25mm chokes, 165 main jets with 210 air correctors and no 10 emulsion tubes. 70 Idle jets & 75 pump jets. This set up is very drivable with just a tiny flat spot @ 2,500 rpm . It returns on average about 25 mpg. I had it set up with 28mm chokes initally ,this had great top end power and the induction noise was fantastic
but there was loads of hesitation on part throttle openings. I have plans to convert the side draught carb to progressive operation which may allow the use of the 28mm chokes without effecting drivability. If anyone has carried out such a modification, it would be great to hear from them.
Charlie
Charlie
Acki
Aki, yes, same kind of thing, below 12 deg C atmos temperature coupled with the right condition of humidity, latent heat of vapourisation of the gasoline will chill the carb sufficiently to make water vapour from the air condense, and then freeze - on - and in the carb, blocking the air corrector jets.
Not good!
Not good!
Charlie
