Limited Slip Differential to Uno Turbo 1,3
Zibi122
Hi.
Can You tell me if LSD from some other gearbox will fitt to my gearbox?
I know that Fita Coupe with 20VT engine have LSD.
Can it fitt to my gearbox?
Julian
Fiat coupe uses a viscous coupling - not a LSD. On the surface this sort of blows that argument up but I've heard a rumour (nothing more) that the viscous coupling bolts quite nicely onto the 1.3 UT gearbox.
The alternative is to get in touch with the likes of Colotti in Italy and buy one of their LSDs (they do two types) - not cheap but very effective. I've heard of one application using a Honda LSD straight out of an Integra Type-R but I suspect that requires a fair bit of surgery and those LSDs have a mixed reputation.
Zibi122
Using the 'search' facility with the word LSD would lead you to this member and his expertise:
http://guy-croft.com/viewtopic.php?t=68
Give him a try, anyone knows more about LS units than I do!
Rich Ellingham
Acki
When you have time you can change the gearbox that the lsd of the coupe fits but I think you have to change many.
In the uno und can use lsd's from the tipo because the turbo have a in germany so called "tipo gearbox".
Look at colloti's page, the have the same number in the catalog (uno turbo and tipo 16v lsd).
lidox19
Zibi122
Julian
Zibi122
Julian
It works by applying a gentle grip to the bevel gears if they are both rotating at the same speed then there should be no friction as they are as good as locked anyway. If one spins faster than the other the blocks provide a braking force through friction and hence try to decelerate the faster shaft and accelerate the slower shaft.
The calibration would (from a quick look) be down to the strength of the springs and in turn how hard they are pressing against the ends of the shafts/gears.
Wear occurs between the moving parts though so you faced with the situation that the gap between the blocks will grow over time and hence the grip weakened. More importantly there will be an accumulation of debris in the gearbox which will need cleaning out. I imagine this setup would be used in grassroots racing where the actual mileage is low as the maintenance could get to be very cumbursome. The other worry is that it would actually damage the gears and shafts over time. At some point it becomes cheaper to just buy a more complex solution that transfers the friction to a more favourable location. To give an example one of the two solutions offered by Colotti utilises copper plates to provide friction. The plates do wear down but the wear is controlled and the softer copper debris is much less damaging to other gearbox components. You still need to maintain a more vigilant gearbox service schedule but that is just part of racing anyway...
SteveNZ
Zibi122
Uros Piperski
I think the guy who made this phantom grip LSD missed the point. According to the Phantom grip manual, you should have 0.127-0.254mm clearance betveen the lsd and the spider gears.
That way the phantom grip lsd pushes the spider gears and locks the diff when the speed difference between the axles is high enough.
The clearance on the photos is 5mm or so... :?: :?: :?:
