Find attached pictures about a head of an Renault 5 Alpine. Is it possible you give me a a priori recommendation on the work to do on it to improve flow ? Of course you have no flowbench trials to validate your answer (humour)...
My suggestion is based on the reading of your different books, you can edit a picture and post it back to show where you should intervene...
It seems the SSR of the exhaust demands more work than intake.
Thank you very much,
Robert
R5 Alpine head modification
Robert
- Bare head
- P1100784.JPG (87.88 KiB) Viewed 12681 times
- Humble Suggestion of mods
- P1100784RG1.JPG (84.93 KiB) Viewed 12681 times
GC_131
Re: R5 Alpine head modification
You are not far off there, treat as I would the Fiat twin-cam, shape is very similar. Same goes for valve angles.
Robert
Thanks Guy. May be we will avoid to remove metal in the exhaust guide area.
Robert
Robert
GC_131
Yes, you need to be careful on the outboard side of the ex valve guide boss - if you make it too thin it may shear when the guide is pressed in.
