Looking for Sample screens for my 2,0 16V
torkil
Post by torkil »
Hi Trying to map My DTA , And i end up with wery high ignition degrees without knocking ,as far as i can hear! using a AFR meter and skilled experience to map in uphill.
Wonder anybody have some sample screens from mapping 2,0 16 V ECU. at least so i can compare a bit. Runs great now, but still worrid about high degrees off ignition . Full thottle on 6000rpm 32 degrees in advance. More on half throttle at 4000rpm.
Have throttle bodies and Two 280 degrees cams ,and 12/1 in compression,
Reg Ove Thorkildsen othorkild@c2i.net
GC_41
Abarthnorway - Remi L
Re: Looking for Sample screens for my 2,0 16V
Hi Torkil!
You never give up do You??! ;-)
Wonderful!
Someone out there sitting on this info?
torkil wrote:Hi Trying to map My DTA , And i end up with wery high ignition degrees without knocking ,as far as i can hear! using a AFR meter and skilled experience to map in uphill.
Remi Lovhoiden
GC_45
