Cylinder head gasket comparison
Biancorally
Post by Biancorally »
here are two engine cylinder head gasket for TC engines, one original and one I do not really know. The first seal is missing a hole on the water pump side, and smaller holes on the opposite side as you can see from the pictures.
Is it advisable to use this first seal?
Daniel
GC_17
Re: Cylinder head gasket comparison
The top gasket is strictly for a reversed port unit. You can see that the coolant holes are (if offered up to the 8v 131 type head) in the wrong orientation - the larger holes should be on the ex side.
Don't know about the lower gasket can I have a photo of the whole thing?
Biancorally
Thank you very much for your help.
I only wanted to know if this first head gasket could be useful to the 130TC. That is not the case!
The lower have to be a stock one, with a thickness of about 2 mm and a bore of 85mm.
Many thanks for the look
Daniel
GC_17
yes the latest one you have shown is right, 130TC late generation OE
