flexhone for bronze valve guides
What grit flex hone should I purchase if I want to flex hone bronze valve guides? target engines include 16V turbo Fiat TC as used in Lancia Delta, Fiat Coupe and such and various Alfa Romeo engines with aluminum heads.
Re: flexhone for bronze valve guides
If tight rough-out with 180 grade Alumina Zirconia and for finishing use 240 grade Aluminium Oxide.
Z grain alumina zirconia is what we use - a bit more durable than silicon carbide. When the hones get worn you can run them backwards but be careful - doing that gives a high removal rate..
Honing new GC guides for fit on a set of good-used & overhauled valves. Drill does 1100rpm and engine oil is the honing fluid. The grade of hone is indicated by the color on the tip of the wire stalk - not the red band below the hones.
CM Head_guide and seat ops (1).JPG (155.08 KiB) Viewed 8374 times
