Sump mod for my Fiat X 1/9 2,0 16V
torkil
Post by torkil »
Hi my simple mod. for my X 1/9 . To little oil volum i suppose 3,8 liter in the sump berore it flows over the tray. Have to hold an eye on oil temp!
All hints welcome OVE
My sump  Mod ,Tipo Pan 3,8 liter,
Sump 2.JPG (106.95 KiB) Viewed 11583 times
GC_41
Re: Sump mod for my Fiat X 1/9 2,0 16V
My 1800 Fiat TC big-wing sumps are not much more than 3.8 liters - work OK provided you keep the oil temp down as you say.
Nice of you to show my new book, Ove - thanks for that kind touch!
GC big-wing sump on this 170bhp 1800 TC on 44 IDF
MW 8V_GC spec.JPG (516.53 KiB) Viewed 11544 times
Is this a hidden challenge? The belt arrangement on that engine in your picture "GC big-wing sump on this 170bhp 1800 TC on 44 IDF" will never work.
Post by TomLouwrier »
Oh but it will. ;-)
It works if you fit the crank front pulley..
in that case a toothed belt drive.
Not Mick Wood's but same setup. Forgot to take a pic of Micks on completion
tmvolumex
Post by tmvolumex »
I agree, the setup will work so long as the custom crank pulley is designed and built to have a proper flange at the back, for guiding the cam belt. As stated elsewhere on this site, you need a flange on both sides of the cam belt. For that matter, the same is a requirement for any toothed belt system, one flange on each side of the belt somewhere in the array of pulleys. For very long belt / pulley arrangements you may need several guiding pulleys. Take a Subaru boxer engine for example.
GC_31
