1975 Beta Coupe project QLD Australia
iano
Dear All,
I thought it was about time I posted some pictures of my 1975 Beta Coupe which I have been steadily rebuilding/modyfying/competing in, which seems to be transforming from a road car into something more serious....All work performed by myself to date, and has been great fun.
The car has cost less than AU$10000 so far (including initial purchase) and has been competing mainly in hillclimbs, and has proven very successful and reliable, winning the road registered up to 2000cc class in my first year of competition and beating RS2000's, Fiat 124 spider, Alfa GTV, Honda Civic Type R and more! (Much to the annoyance of my fellow competitors who spent much more than the entire cost of my car on their engine alone!)
Overview so far:
Engine: original 1800 TC unit replaced with 2 litre TC
84.8mm rebore with new cast 105TC pistons approx 10.8:1 static CR
crack tested & polished/balanced std crank
lightened flywheel to 6.3kg, crack tested/balanced with crank & front pulley
std low mileage rods
modified aux shaft
baffled sump with windage tray
Oil cooler/tstat/accusump/catch tank
Ford Focus ST170 radiator
In head Thermostat, heater outlet from head plumbed into top water rail
Goetze head gasket
2 l Beta Head with std 42mm valves/3 angle seats/30 deg back grind inlets (needs more work.....)
42/82/82/42 "Autocross" cams 10.6mm lift from unknown US source (suspected welded up regrinds....)
Twin 45DCOE on GC inlet, 36mm chokes, remote filter
4/2/1 tubular manifold, 2" exhaust system
Wideband lambda sensor & gauge for checking AFR
B9EGV spark plugs
Suspension:
Spax top adjustable gas shocks, lowered springs, strut brace, urethane bushes, 2 degrees neg camber front.
Wheels/Tyres:
15x7" with Toyo R888 205/50 x 15 or std Beta 14x5.5" 185/60 x 14 Toyo R888
Brakes:
Std Beta with uprated pads/steel braided brake lines -work in progress
Overview so far:
modified aux shaft
Goetze head gasket
B9EGV spark plugs
Suspension:
Wheels/Tyres:
Brakes:
GC_47
LanciaNut69
Re: 1975 Beta Coupe project QLD Australia
Hi there Iano,
Thanks for sharing - that is a very clean looking car and a nice install. Good to see these cars campaigned to such good results. Every time I see a Beta Coupe it makes me hanker after my first Lancia!
thank you
Darren
thank you
Darren
__________
Book #435
Book #435
iano
Thanks for the kind comments Darren.
To be honest there have been times when something newer, and/or with rear wheel drive would have been better suited to competition, but I like the challenge, and after all you don't see many Betas on track, especially in Australia!
Latest mods include a strut brace and new coolant header tank.....
I also have an in car video of my first time out on a race track last year, at the Ironman sprints Queensland raceway: http://youtu.be/XR2jmYLH4JI
Ian
Ian
GC_47
fingers99
Very tidy car.
I can't remember the last time I saw one on the road here.
From the clip, it was well worth all the effort!
GC_06
LanciaNut69
Hi Ian,
Looks like you had great fun out on track! Look forward to hearing more as you progress.
All the best
Darren
All the best
Darren
__________
Book #435
Book #435
S&B125
Hi
Love your car! I had one much the same a 1975 in red in the early nineties and still regret selling it. Well done you for getting a Beta out there and competing. We have a rather quick one over here in WA, though it is the very last of the models and shares the same grill as your car. There is another 1975 Coupe being developed at the moment but is still some time from hitting the track. Funnily enough it was my Beta which led me to the joys of these wonderful engines and at the time I never imagined I would get into old Fiats the way I have. Great Video.
GC_35 Fiat 125T
That is one sweet looking car you have there. I can totally imagine you're holding on to this, even though RWD is tempting.
iano
It has been a while since I posted, but here are a few videos of events last year, first at Lakeside Park racetrack, then Queensland raceway for the Festival of Italian Motorsport, which was great fun, managing 4th place overall against a field of Alfas, Fiats and Ferraris.
http://youtu.be/tEOawdTD6kY
http://youtu.be/a6qjP1uUcLM
http://youtu.be/h-Zx3h02Gf8
Coming very soon is a full race GC engine, featuring HC forged pistons, race rods, full race spec VX head with 4A/3D cam combo, fully revised under bonnet layout with new radiator, 4-1 big bore exhaust etc.....
GC_47
iano
iano
More pictures, this time from Festival of Italian motorsport last year, which I am entering again this year on September 8th.
GC_47
MODEL POST!
Nicely described with tech detail and beautifully illustrated from the start.
Particularly pleased to see the sealed intake!
Thanks Ian!
Thanks Ian!
iano
Thanks Guy,
The sealed intake is a must in Queensland as the ambient temperature reaches 35+ degrees C. I measured the intake air with the original offset radiator and the carb was ingesting air at 50+ degrees C!!! In its current location intake air remains at ambient. I also insulated the air box with self adhesive "armaflex" to further prevent heat transfer.
GC_47
