Fiat 128 model '72 -Stage 1-
federico_878
Post by federico_878 »
Hello my name is Federico. I live in Buenos Aires, Argentina
I present my car is a Fiat 128 model '72.
Engine SOHC:
-1100 cc to 1400 cc.
-Tipo's crank stroke 67.4mm
-crankshaft has worked the benches.
-forged pistons, bore 82.5mm and volume 7cc.
-polished rods, lightened, keeping your weight evenly between the 4.
-cylinder head gasket sheet thickness of 0.6.
-cylinder head: * ducts worked
*worked Heaven
* worked valve seat
*valves are developing a new
* worked valve guides
-Fiat 128 camshaft IAVA 1300cc 102hp.
-Megasquirt 2 only work spark.
-Weber carburetor 32 mm to 40 mm, original broadcasters.
-steel flywheel weight was reduced from the original.
-gearbox Lancia (Fiat 1, Fiat Tipo, Motor type in a few words).
-clutch: original plate, disc brake pads 3 and fixed center
Front:
-adjustable arm ball
-elastomer bushings are developing.
-original roll-bar
-shock compression and worked in expancion
-will work in the spring, reducing the height.
-wheels 13" original Fiat Uno Turbo
-undefined tires.
-disc brake and calipers Fiat Palio ventilated
Rear:
-is being re-designed
Interior:
-instrumental Fiat 128 IAVA 1100cc
-"torpedo" in the process of restoration
-steering wheel Renault R19 RTI Coupe (redesigned, obviously)
-seats, waiting for a surprise.
P.S.1: I apologize for my English is not very good. If you need to modify the post, no problems.
P.S.2:The photos go up tomorrow, I have them on this pc.
federico_878
Re: Fiat 128 model '72 -Stage 1-
Hi, I brought some pictures of the car and engine parts.
Photos of the car when I buy it:
After changing some parts:
Reinforcement was performed on the body:
In the workshop of the painter
Work can be seen on the cranks:
Engine 1100 cc to 1400 cc:
Forged piston:
Reform to the command switch:
Sorry for my English not very good. And soon I will be counting as the next stage is made.
Should they have any questions ask me.
Byee
federico_878
any suggestions?
Sorry Federico
been that busy lately hardly been able to write on the site at all. Doing my best.
Will look in on this one when I get a moment slightly longer than 2 minutes without the phone ringing.
In the meantime !! MEMBERS!! can we have a bit of enthusiasm for this super project from a friend so far away?
Ta
Post by Brit01 »
I'm probably your closest neighbour being just across the rio de la plata (Pocitos-MVD).
You are taking on a big project there federico_878 by the looks of it. Total restoration.
Can you find parts easily in Buenos Aires?
From 1100 to 1400 is a dramatic increase. Are you working on this yourself or have technical assistance?
NineOneSix
Post by NineOneSix »
Quite a project your taking on there! I love the old Fiats. Good luck with the project!
Oh and your English is fine, I would not worry to much.
federico_878
Guy Croft wrote:Sorry Federico
Ta
Thanks Guy.
Brit01 wrote:I'm probably your closest neighbour being just across the rio de la plata (Pocitos-MVD).
Is true we are close.
With regard to motor much in the market. Parts for the body there are varied quality and poor quality.
Don't understand what the "technical assistance"?
NineOneSix wrote:Quite a project your taking on there! I love the old Fiats. Good luck with the project!
Thanks. This project takes me a long time...
federico_878
News:
Buy Fiat Uno Turbo wheels 13 "x 5.5".
Some pics
many pictures up tomorrow.
Post by Brit01 »
I can relate to you about the poor quality of products here in South America. I try to buy smaller/critical parts from Europe if I can.
What I meant about "technical assistance" was that if you had help or are working on the car alone? Re-boring etc.
federico_878
Chris:
work alone in my car, sometimes I ask for help to colleagues / friends, if only I can not do.
Regards.
podd37
Post by podd37 »
Great work...kep us all informed
Post by Brit01 »
Any updates Federico?
Been a while since we've heard anything new about your 128.
federico_878
I get some time today and tell them the news
