123 Distributor
MinorTC
123 Distributor
Has anyone tried a 123 Distributor on their Fiat twin cam?
They sound very promising...
Maurice,
East Kent.
East Kent.
MACAuto
Re: 123 Distributor
MinorTC,
I purchased one for my 124 Spider 1756 8V TC street car. A very nice distributor. 15 different advance curves, selectable by detent potentiometer accessible on the underside of the unit. Easy to set-up, and stable operation. For the TC with Exhaust cam drive, you will need the spiral drive gear from another Fiat distributor, but the unit comes with the shaft ready to go, complete with a roll pin for install of the donor drive gear. Made in The Netherlands, so I most likely paid too much from a USA Vendor. Very slick indeed.
MACAuto (Bill)
MACAuto (Bill)
Re: 123 Distributor
Anyone got a photo or a link?
At first I thought it was a 'typo' and meant to be '124' but clearly it's not!
More info please.
More info please.
petarn_vx
Re: 123 Distributor
wow !
someone actually making and LISTING a new distr for TCs. Thanks, I must find out more, distrs have been a 'thorn in my side' for years.
MACAuto
Re: 123 Distributor
I believe that the 123 in the name refers to "as easy as 1-2-3", which, in my opinion, this product clearly is. Curiously, the first Fiat application was for the 600 thru 900 variants, and has been applied for the TC only recently. An Alfa TC version is also available. There are 15 different settings for various timing curves, set by a pot in the base, as mentioned above. There are electronics located in the body of the unit where an LED lights up in a window, when base timing is set correctly, for the axial index position desired (cap leads pointing in the desired direction). Make a fine adjustment to the body with an indexing timing light for desired maximum advance, lock down, and it's finished. Comes with cap and rotor. The case appears to be machined billet, and is polished.
MACAuto (Bill)
MACAuto (Bill)
Re: 123 Distributor
Thanks Bill,
I've just bought a Computronix unit from Mark at Allinsons, beautifully made but you have to alter the advance if you want to (which I need to for the TC) with weights and springs, so this looks like the next generation really.
MinorTC
Re: 123 Distributor
The 'potentiometer' in the base of these is actually a hexadecimal switch - quote from manufacturer's instruction manual:
"You may wish to verify that the correct advance curve has been selected in your '123' : using a
5mm Allen wrench remove the hexagonal plug in the bottom face of the housing. Inside the
hole you'll find a 16 position rotary switch, marked '0' to 'F' ."
So, you are switching in a different advance curve for each of the sixteen positions.
Maurice,
East Kent.
East Kent.
