Hi!
I am currently building a 130 tc engine using only std Fiat parts.
I am considering to narrow down running clearances on the cams, to gain some lift and duration.
How close may I go without sacrificing reliability?
What factors determines this`?
What are the potential drawbacks on having the valve slightly open during the slow opening/closing phase? (for 124 cam - see PDF)
For interest I am submitting a comparison graph for 130TC cams (high milage) and 1800 sport (low wear).
As You can see the opening (ramp) is very different between the two.
BTW - how do I submit the graph into the post - not as an attachment?
Best regards
Remi Lovhoiden
Minimum clearance using standard cams??
Abarthnorway - Remi L
- Cams Abarth vs 1800.pdf
- (191.89 KiB) Downloaded 694 times
Last edited by Abarthnorway - Remi L on October 13th, 2010, 1:21 pm, edited 2 times in total.
GC_45
Giulio
Re: Minimum clearance using standard cams??
Abarthnorway - Remi L wrote:...
Best regards
Remi Lovhoiden
Hi Remi,
you can simply open the pdf file, then use the Print/Stamp key ( or Alt + Print keys) on your keyboard to copy the entire desktop ( or only the selected window) as an image; then open for example Microsoft Paint ( or another graphic tool ) and paste the image !
Save and upload !
like this !
(I hope this is what you need.)
Bye
Giulio
- Immagine.JPG (33.75 KiB) Viewed 8395 times
I use 16 thou" inlet and 18 thou" ex (+/- 2thou") as a rule on all the TC 8V cams, I would not advocate going any tighter.
