Hi to all,
I'm making a BMW 2002ti rally car and I'm not abot C.R. and cam.
I have a new set of J.E. forged pistons, with these pistons I'll get 10,5:1 C.R.
Can I use a 316º Scrhick cam with this C.R.?
Will work fine?
Cam Lift (valve lift) I/E mm: 9.1 / 11.9
Duration: 316º/3116º/100º
Valve timing: 58-78-78-58
Valve lift at TDC: 5,6
It's the P.N.:0002 01 160-03
http://www.avl-schrick.com/dat/MK/Schri ... 09%20E.pdf
Thank's in advance for you help.
Best regards,
Alex.
BMW M10 engine C.R.
alexfl82
Re: BMW M10 engine C.R.
NO PROBLEM AT ALL!
tmvolumex
I would be sure to check piston to valve clearance with a dry build, as should be done in any application changing cams. Especially if changing cams and pistons! Guy details this procedure on this site.
GC_31
