Hello
I have installed EDIS ignition in my twin cam engine. Everything works OK, apart from tachometer. I have tried many different solutions, but with no success. I decided to go for external tacho. Does anybody know a producer of tachos, that will work for sure with EDIS system?
Slawo
Tachometer for EDIS ignition system
Slawo2000
Slawo
Book no. 179
Book no. 179
Maki
Re: Tachometer for EDIS ignition system
Try using 11 pin from EDIS module as for the tacho signal
RST ZVH
dp
It may be possible to run your tacho off the EDIS coil by taking the pulse off both coil low tension wires. you need to fit some diodes so to stop current to one coil also firing the other one. Diodes are just acting as one way valves for the electricity.
If you can look at the bottom of this page, there's a diagram with part numbers:
http://www.megamanual.com/ms2/EDIS.htm
