Fiat 128 - ignition advance
philippe74
Post by philippe74 »
Hello
I finished my latest car, it's an Fiat 128 3P.
I will use it in the french hillclimb championship for historical races,in group 2.
In France the name VHC ( véhicules historiques de compétition). I would like to have your opinion about ignition advance.
I got few informations about it, but I would like to compare with your suggestions.
First, you have to know that I have to keep standard ignition system ( due to FIA regulation)
Volumetric ratio is 10.6, engine is prepared for high rev's (maxi: 9000 RPM)
Informations I got from a pilot in Italy is to adjust to:
max: 28° at 4000 RPM ..Otherwise, ther would be a big risk for the pistons ( which are forged)
It's seems realistic ...
What are your comments ?
Philippe74
PS: if somebody needs more infos about this engine to give an answer ...no problem
James Bowen
Re: Fiat 128 - ignition advance
Post by James Bowen »
Phillippe,
My 1500cc Fiat SOHC engine which has forged pistons, and comp. ratio of 10.8:1 revs to 7,500 rpm, has 30 deg max advance. There was no more power to be had from more advance, and only slightly more at 30 than at 28 degs. ( I mean fractions ) The engine has about 28 degs by 4,250 rpm. Swinging the ignition on a fully open throttle did not seem to affect power readings much at all.
Hope his helps,
Regards, James Bowen
philippe74
Thanks James
I forgot to say that my car is a 1300 cm³
Anyway, it seems to reach this 28° value ...is OK
Philippe
A view of piston + conrod
bloc jaune fini (2).JPG (67.49 KiB) Viewed 12735 times
philippe74
Hi
Impossible to obtain 28° at 4000 RPM and also a correct advance at iddle speed !! My engine at 1000-1500 rpm knock and stop
If I want to start engine easily, I have to increase a little bit advance, but after I have approx. 30 to 31 ° at 4000 RPM
Do you think it could be due to the springs ? may be they are too soft ?
is it possible to find new springs ?
Philippe
Could be a problem with the contact breaker setting in the distributor.
philippe74
Guy Croft wrote:Could be a problem with the contact breaker setting in the distributor.
OK ... I will have a look
thanks
Philippe
