Torque settings
CraigAPD
Torque settings
Post by CraigAPD »
Im pretty sure I seen a tech guide with all torque settings for Coupe 16v Turbo engine on this forum? Or am I imagining things?!! If there is could someone link it for me please.
If there isnt such a guide, maybe someone would be kind enough to post engine torque settings (namely main bearing caps, flywheel, cank nose bolt, head bolt, cam carriers, cam gear...)? Also timing belt and balance shaft belt timing procedures would be very handy.
Many thanks
Craig
Re: Torque settings
Sorry - I personally don't have that,
AndrisV
Re: Torque settings
Post by AndrisV »
Here you are. Although it would be wise to check against other sources.
Attachment deleted by GC:
I know we're all short of data and I know you're trying to be helpful but you must NOT publish copyright documents here - written by Fiat or anything else. You may rewrite tech data and publish that (as I do myself) but you may not simply copy it. I've got enough problems with people pdf'ing my own published work without having Fiat 'on my back'. I strongly suggest you read the Protocols again, especially para 12 which you have directly violated:
http://guy-croft.com/viewtopic.php?f=16&t=1194
What you do between yourselves by pm is of no particular concern to me.
