After many hours welding I am now about to rebuild my X1/9 to modified sprint/hillclimb spec to compete in the under 1400cc catagory
So I am ready for spring I am refitting the original 1300 engine in my Fiat X1/9 and want to fit my twin Weber 40 DCNF carbs. The engine is for now completely standard apart from the carbs, CSC 4 branch manifold and system. I would be very grateful if you could give me some advice on appropriate jetting for the carbs. The setup at the moment is :-
Choke - 30
Main jets - 140
Idle jets - 65
Emulsion tubes - F36
Air corrector jets - 210
Accel pump jets - 35
Aux venturi - 2.5
Needle valve - 1.75
To be honest I have no idea what these where jetted for so don't want to try running the 1300 without first getting a reasonable baseline to work with.
I have aready read and taken your advice for a Silver Top fast road pump with no regulator.
Any advice would be gratefully accepted!
thanks as always
Guy
On another note I have found a company that is suppling X1/9 manifolds as well as many others thought it might be of interest
LINKS BY PERMISSION ONLY READ PROTOCOLS
X1/9 1300 DCNF Jetting
GPW
- manifold.jpg (32.4 KiB) Viewed 11753 times
GPW
Re: X1/9 1300 DCNF Jetting
Sorry about the link Guy
missed that in the rules. Won't happen again. Just thought it would be useful to all members finding it hard to get a manifold for there project. I haven't used the company myself as my carbs came on a old manifold like the one in the photo.
Apologies again
Guy
Apologies again
Guy
It's OK. Remember I'm only a PM away though!
More later..
More later..
Original standard X19 1300 on 40DCNF
Choke - 30 - OK but a bit small - 32 better
Main jets - 140 - too big (rich) go 120
Idle jets - 65 - too rich - go 45
Emulsion tubes - F36 - no - use F21
Air corrector jets - 210 - maybe a bit big (lean) go 200
Accel pump jets - 35 OK
The performance will depend to a very great extent on the layout of the ex manifold and back pressure in the silencer.
GPW
Many thanks Guy,
I have started ordering the parts. The F21 emulsion tubes are being difficult to source. I have tried Webcon who no longer supply the F21 and supersede onto the F22. The difference according the Webcon is the F21 tube has a diameter of 5.7mm and the F22 is a 6mm diameter. The hole layout of the two tubes is the same. I have also tried the usual Google search but nothing there either.
What do you advice? Or do you have any F21's that I could purchase from you?
Guy
Guy
You can certainly use F22, no worries, they are interchangeable with F21.
