Engine weight
dp
Engine weight
How much does a Fiat or Lancia 8v 2.0l engine weigh please?
Re: Engine weight
I have no data on this, sorry.
Uros Piperski
Re: Engine weight
I don't have any data on this either, but I can say that it depends on the type of engine. The block height is different on 1.6, 1.8 and 2.0 engines, blocks with balancing shafts have some extra weight too. The brackets for aux devices are various sizes and materials, 16 valve head is heavier than the 8 valve etc etc... So you really have to specify the vehicle type and maybe someone will come up with an answer.
dp
Re: Engine weight
It's a 2.0l 8Valve from a 1977 Lancia Beta saloon but it's aligned RWD with an Argenta sump and rwd oil pump. The head is the early type with more widely spaced cam boxes; the inlet to the right and exhaust to the left as you look at the cam wheels in RWD alignment. There is no balance shaft.
I'm not looking for the exact weight so the weight of any 2l 8V pre balance shaft unit will give me a good enough ballpark figure.
Testament
Re: Engine weight
It is around 150kg for a complete 2L motor out of a 131/132/beta
something like (approximate weights)
bare block - 50kg
crank - 17kg
rods and pistons - 5kg
complete head with cams - 25kg (maybe more?)
manifolds and carb - 10kg
107kg so far then the rest would be in bearing caps, sump, oil pump, aux. shaft, water pump, various pulleys, alternator, oil seal housings and a few other things. so I think 150kg is probably pretty close. the twin cam isn't the very lightest 4cyl around, but its not too heavy - and its very compact for a two litre.
bare block - 50kg
crank - 17kg
dp
Re: Engine weight
Many thanksTestament wrote:It is around 150kg for a complete 2L motor out of a 131/132/beta [...]
Re: Engine weight
Weighing by part, never thought of that.
Actual:
Block & caps 45kg
Head built less manifolds 25kg
Crank 18.5kg
Actual:
Block & caps 45kg
Crank 18.5kg
Re: Engine weight
Great idea.
I will be building my engine soon and will document the whole process. I will make weighing it a part of the documentation.
Once done will make this available to members.
tmvolumex
Re: Engine weights
There is an engine weight data sheet listed on the web for kit car builders etc. If you do a search using "Auotmotive engine weights" you will find the list. It was compiled by a guy named Dave Williams. The list contains a couple hundred engines. Everything from Alfa to VW. The only Fiats on the list are the Fiat Dino 2.0 and 2.4.
GC_31
