Selecting Carburetor Choke Size
benlilly
Post by benlilly »
I have found quite a bit of info on selecting carb choke size based on bhp and rpm but the result seems to differ depending on the source of the information.
Would a good basis for selecting choke size for my Dellorto 45's be the peak flow of my head? When you tested it for me you found it peaked at 105CFM @10' depression and 10.4mm lift (results below)?
Ben Lilly 205GTi.pdf
(13.43 KiB) Downloaded 584 times
BL peak flow.jpg (111.23 KiB) Viewed 5675 times
In your 'General Tuning Hints' section of the website you say that a 33mm diameter hole will flow 102 CFM @10' depression. For a larger hole the flow will increase by the ratio of the radius/diameter squared. Based on this, for my choke to flow 105 CFM, I would need:
105/102=1.029
(33^2) x 1.029=1120.581
Sqrt 1120.581=33.475mm choke (round up) 34mm choke
Is this a good way to look at it?
Ben
Re: Selecting Carburetor Choke Size
Sure Ben,
I'd use 34mm or for more power 36mm chokes,
benlilly
Post by benlilly »
Ok. Thanks very much.
Ben
