I have a Beta Spyder 2 litre that currently resides in the South of France. Prior to relocating the car I fitted a low-temperature radiator fan switch and now wish to complete my precautions by fitting a low temperature in-head thermostat to the engine. Can you tell me what list of parts I will require (I have already sourced the GTS 102 thermostat) to complete this, and what components are subsequently connected together when I discard the external thermostat? A source for the parts would also be appreciated.
As they say a picture is worth a thousand words, so if anyone has pictures of this conversion they would be very gratefully received. I also recall reading in another thread some time ago that it is worthwhile routing around the heater matrix to avoid possible head gasket problems. As the car is only ever used in the summer in the South of France a heater is pretty much superfluous, so any hints and tips on doing this would also be welcome, along with any parts required.
Thanks in advance.
Lancia 8V In-head thermostat requirements
Graham Stewart
Re: Lancia 8V In-head thermostat requirements
The top rail needs to be opened out to accomodate the stat properly and when done it is bonded to the head with silicon sealant - there isn't a suitable gasket for that setup.
The outlet on the rail (red square in photo) thaqt ordinarily goes to the OE external stat needs to be blanked off.
Make sure the GTS stat has a 3mm air bleed hole - if not drill one thru the flange and make sure the rail doesn't close it off (ie: make sure you generate enough clearance when you open it out and makes sure you don't break thru the brazed joint betw rail and flange in doing so..)
That's all,
That's all,
- GC Vx short engine.JPG (35.77 KiB) Viewed 7954 times
Graham Stewart
Thanks very much for that; I've got all the parts so can start on it straight away.
Regarding the heater matrix (and routing around it), would you say this is desirable? I do seem to remember reading some posts on here a while back that recommended it in the interests of not blowing head gaskets.
Thanks again,
Graham
Thanks again,
Graham
I would not bother doing anything with the heater setup,
Graham Stewart
Many thanks.
Many thanks.
