Hello I bought me a real 131 Abarth Stradale transformed to Gp4 with Colloti gear-box /Gp 4 Bilstein suspension/ big brakes /Kugelfischer injection from Abarth.
I will drive rally with the car but the engine does not have dry sump but a big-wing sump pan. What’s better dry sump or a modified oil pump?
GEERT
131 ABARTH 16V
DUC999S
Re: 131 ABARTH 16V
Good for you Geert1
Dry sump is of course better (no aeration and constant feed) but it's complicated to set up and costly. Might be OK with the sump you currently have and use an 1.5qt/2qt oil pressure accumulator like Moroso or Canton.
- this is how an oil system with accumulator is set out
- Moroso layout.JPG (40.03 KiB) Viewed 9989 times
- The accumulator operates via air pressure at the gauge end, has a piston inside and stores oil under pressure, discharging into the main gallery if the engine pressure drops.
- Moroso 1.5qt & clamps.JPG (22.98 KiB) Viewed 9989 times
- This is a dry-sumped unit, modifed steel pan can be used of course. Pump is Titan 3 stage, one pressure two scavenge. A large array of ancillaries and hose is needed.
- OSC 16v built (2).jpg (438.37 KiB) Viewed 9990 times
