Fiat coupe 16v non turbo project
stefan89
Post by stefan89 »
Very start of the project, going to rebuild engine
Image008 (600 x 450).jpg (68.11 KiB) Viewed 8443 times
Image042 (600 x 450).jpg (84.62 KiB) Viewed 8431 times
Image059 (600 x 450).jpg (75.91 KiB) Viewed 8431 times
Image063 (600 x 450).jpg (68.29 KiB) Viewed 8431 times
Image068 (600 x 450).jpg (82.92 KiB) Viewed 8433 times
Stefan Butler
Re: Fiat coupe 16v non turbo project
How nice to see a 'non-turbo' and 'non-400bhp-monster' Coupe project at last!
I so look forward to hearing more.
(always wanted a Coupe by the way, ever since that advert 'no-one in Italy grows up wanting to be a train driver'... never did get one!)
Rich Ellingham
Post by Rich Ellingham »
Hello Steffen, please have a look in the competition section at my tipo 16v. You may be aware that between the Tipo series 2 16v and the coupe 16v na there are very few differences, also remebering the body floor pans are the same so all engine locating points are also the in the same place. Infact there are virtually not differences mechanically.
Rich
book 38
stefan89
Post by stefan89 »
having stripped the bottom end parts and taken them to be assessed, here are the main things that need to be done, apart from gaskets etc,
new bearings
crank has been scored, they have told me that the crank can be ground because it is a n/a engine however i have heard guy say that is maybe nitrated so not sure?
new oil pump (on the look out for one)
block honing and piston re-ringing - 3 or 4thou" clearance think he said they have
con rods have compressed 3thou" (think this will be the biggest problem, because sorcing new ones will be a problem, as not sure if i can trust second hand ones unless i take a micrometer to check them?)
can any one advise me on a trust worthy place a can get some standard con rods from that will be ok, I'am bit worried that if i get second hand ones that i might get the same problems might have been in a car engine that has over heated? think guy has stoped dealing with standard con rods and pistons? Any advise would be great thanks,
just been told that the con rods could be sent away to be resized which might be a better option?
Stefan Butler
Users browsing this forum: No registered users and 52 guests
