X19_Tipo_Tempra_Uno head fitting
Locked
Attached is a download of a GC 'How to' article about fitting these heads that I wrote recently after doing such a heda for for a client with an X19.
Not quite as easy as it looks. If you never fitted one of these heads before, especially if it has competition cams and top hat shims, have a good read. It's easy to put these heads on and completely mess up the shimming by dropping the top hats, buckets and tappets on the floor!
X19_Tipo_Tempra_Uno SOHC head fitting.doc
(1.36 MiB) Downloaded 3875 times
Re: X19_Tipo_Tempra_Uno head fitting
and shimming up...
Shimming SOHC.doc
(1.35 MiB) Downloaded 3244 times
Locked
