Shimming tools 8V, 16V Fiat TC & Fiat SOHC
Walezy
Post by Walezy »
Hello,
Is the shimming tool for 8v head suitable for 16v head? Is this the same tool or there is a special one for those heads.
Tomasz
No it's not quite the same as the 8V.
The 16v shimming tool part numbers are:
Pressure lever (also used on 8V unless you simply rotate cams to insert the 8V positioning tool) 1860443000
Positioning tool 1860747000
I stock the 8V shim tools - notoriously hard_to_get.
16v - You depress the bucket and lock it down with the pos. tool to get the shim out.
16v Fiat pressure lever - top and positioning tool.jpg (112.55 KiB) Viewed 8882 times
8V Fiat - you can rotate the cam to full lift and insert the shim tool or use the pressure lever to depress the bucket and then insert it.
8V Fiat TC shim tool.JPG (16.1 KiB) Viewed 8880 times
SOHC X19 type shim tool, factory manual shows it inserted with cam at full lift, never had much success with it, always seems to slip out!
Fiat X19 type SOHC pressure lever 1860642000.JPG (151.75 KiB) Viewed 8881 times
Walezy
Post by Walezy »
Thank you for the info. Do you know where i can get the shipping tool for 16v?
It's an order from an apppointed Fiat dealer unless you want me to get one, subject to availablity from Fiat, I often do, contact me by email if you do please.
