The picture was taken at Brands Hatch back in 2003 and shows off some experimentation in how to cool a snug-fitting mid-mounted engine. Extra ducts on the rear arches feed an intercooler mounted where the number plate used to be while the radiator cowling was removed and new ducting built to flow the air through the bonnet, hopefully in a cleaner manner than the original Dallaras and Prototipos. The result was hideous front end lift at about 120mph...
The engine lasted one race (actually it didn't even last that long) due to a small faux-pas on my part and a big faux-pas on the part of the engine builder. I hadn't run the engine often enough while it was in storage and the original engine builder had fitted sleeves to the bores and neglected to pin them relying instead on a dubious interference fit to keep them in place.
In a rush to just get the car back on track I resorted to using an early 1.3 Uno Turbo engine instead and while it was quick it wasn't reliable. Another engine builder got the sack after I discovered the water pump (an electric substitute) had been fitted incorrectly and was bypassing the radiator.
Currently the car is undergoing a slow total rebuild with a completely new engine.
