Lancia Dedra Integrale
hepe75
hepe75
Re: Lancia Dedra Integrale
some video for gruppo Fiat finlandia/Lancia club finland track day
Ahvenisto Track On-board summer /road tyre
Rantapirtti sprint track On-board/road winter tyre, No spikes
Dedra Integrale
hepe75
Videos on Google, well done!
Some film hosting services are banned from this site, but Google I must look into!
What fun your films are, it's great to see some 'sound and vision' here, thanks!
hepe75
Wow you're skilled!
I'm very impressed indeed. Thank you for sharing your work with outstanding photos.
hepe75
integrale
Hi hepe75.
What gear box you used original from Dedra or from Delta integrale?
And what clutch you used?
Regard Kiril
Regard Kiril
hepe75
I use orginal gearbox(it's same delta integrale) but I change rear differential from Delta integrale, because there is TORSEN and Dedra rear differential not
Clutch disc 228mm(orginal 235mm)
and clutch assembly is 30% more stiff to orginal
Dedra Integrale
arjunior45
Ev0luti0n_
Congratulations on the car and the job done! For sure a lot of money and expertise involved!
I enjoyed a lot viewing the pictures! Good luck with the car
hepe75
I had a one-year break, for Lancia building...
but now i start building again
DIY
exhaust manifold + New turbo(gt 28 76)
DIY
intake manifold(not ready)
intake manifold & not painted exhaust manifold
and yes, the throttle should be in a different direction than usual
DIY
DIY
Dedra Integrale
I do recommend that you spend more time on the header and try to improve the ratio of chord radius to pipe ID. Ideally you want a ratio of 2:1 or better - in other words the most generous chord rad you can get. I've tested several aftermarket tubular headers lately from turbo 4 cyl units and the pressure drop due to adverse bends is very high - near 50% in some cases.
- adverse chord/pipe ratios marked in red
- 09112009935.jpg (48.27 KiB) Viewed 29100 times
- shiny but functionally useless - this on a port with 111cfm @ 10" ex bare port flow
- header_01 on test - worst port is 2 with only 83% on 81.9cfm flowscale.jpg (443.01 KiB) Viewed 29100 times
hepe75
I know that this is not perfect, but it has my own manufactured(first one ever) and the target is that it would be better than the original exhaust manifold is
Dedra Integrale
As pre usual practice here my comments are constructive observations and not - criticism.
Without testing the original manifold you have no way of knowing whether yours is better or nor but be aware that it is easier to generate beneficial curvature with a casting than tube (in confined layouts anyway..) and it is a common misconception that pipe will be better 'per se'. It will not be if you have very restrictive bends like your layout has.
