Lancia Dedra Integrale
hepe75
Re: Lancia Dedra Integrale
Post by hepe75 »
both adjustment caster/camper
centre part is rotating
Dedra Integrale
hepe75
Post by hepe75 »
Dedra Integrale
hepe75
Post by hepe75 »
Dedra Integrale
Videos on Google, well done!
Some film hosting services are banned from this site, but Google I must look into!
What fun your films are, it's great to see some 'sound and vision' here, thanks!
hepe75
Post by hepe75 »
rebuild intake manifold
throttle body 70mm Dellorto
Dedra Integrale
Wow you're skilled!
I'm very impressed indeed. Thank you for sharing your work with outstanding photos.
hepe75
Post by hepe75 »
Dedra Integrale
integrale
Post by integrale »
Hi hepe75.
What gear box you used original from Dedra or from Delta integrale?
And what clutch you used?
Regard Kiril
hepe75
Post by hepe75 »
I use orginal gearbox(it's same delta integrale) but I change rear differential from Delta integrale, because there is TORSEN and Dedra rear differential not
Clutch disc 228mm(orginal 235mm)
and clutch assembly is 30% more stiff to orginal
Dedra Integrale
arjunior45
Post by arjunior45 »
hepe75 wrote:Image
that's a piece of art! Congrats.
Wish I could make a couple of them for my Alfa Romeo 155 Q4.
you have a pm.
Nick
Ev0luti0n_
Post by Ev0luti0n_ »
Congratulations on the car and the job done! For sure a lot of money and expertise involved!
I enjoyed a lot viewing the pictures! Good luck with the car
hepe75
Post by hepe75 »
I had a one-year break, for Lancia building...
but now i start building again
DIY
exhaust manifold + New turbo(gt 28 76)
DIY
intake manifold(not ready)
intake manifold & not painted exhaust manifold
and yes, the throttle should be in a different direction than usual
Dedra Integrale
I do recommend that you spend more time on the header and try to improve the ratio of chord radius to pipe ID. Ideally you want a ratio of 2:1 or better - in other words the most generous chord rad you can get. I've tested several aftermarket tubular headers lately from turbo 4 cyl units and the pressure drop due to adverse bends is very high - near 50% in some cases.
adverse chord/pipe ratios marked in red
shiny but functionally useless - this on a port with 111cfm @ 10" ex bare port flow
header_01 on test - worst port is 2 with only 83% on 81.9cfm flowscale.jpg (443.01 KiB) Viewed 29112 times
hepe75
Post by hepe75 »
I know that this is not perfect, but it has my own manufactured(first one ever) and the target is that it would be better than the original exhaust manifold is
Dedra Integrale
As pre usual practice here my comments are constructive observations and not - criticism.
Without testing the original manifold you have no way of knowing whether yours is better or nor but be aware that it is easier to generate beneficial curvature with a casting than tube (in confined layouts anyway..) and it is a common misconception that pipe will be better 'per se'. It will not be if you have very restrictive bends like your layout has.
