digiplex question
midge
digiplex question
Post by midge »
Can anyone please tell me if it is safe [ for the unit ] to crank the engine over on the key with the live feed from the ign switch disconected fom the coil ? I want to run a compression check on my Lancia delta engine without the hazard of the high tension sparks from the digiplex unit.
many thanks.
Re: Digiplex question
Quite possibly not. You should disconnect the coil and unplug the multi-pin socket from the Digiplex unit too.
midge
Re: digiplex question
Post by midge »
Thanks Guy, good thing i thought to ask!
SteveNZ
Post by SteveNZ »
For a compression test, its better (and easier) to just unplug the crank angle sensor. There will be no spark or fuel injection.
midge
Post by midge »
Thanks Steve.
