Fiat Spider, 8V engine and things
cos
Hi Guy and all in the forum, although difficult to find the time I'm always keen to browse through this forum as I'm an admire of Italian machinery and even more so of the twin cam engine.
I've own my SC2 spider for nearly 15 years now and besides the usual messing around to get more power with cams compression and twin 44's it was about time I took it it to the next level. So a year ago I decided to spend every available lunch hour having another go. This time it was going to be fuel injection. And must reduce the weight. I'm privileged to be working in the motorsport engine industry so i twisted all my suppliers arms to get the max discount and most were very happy to do so.
I've kept an excel file with the weight records and even though the engine is not complete yet 6.1 kilos have gone! Amazing. Most of the weight has come off the right areas like piston / rod assemblies (steel rod/forged piston), replacing heavy steel bracketry and plates with aluminium, and with the abundant use of titanium bolts courtesy of a friend who works for an F1 team and titanium bolts are no longer allowed to be used there. I completely removed the Auxiliary shaft and instead modified the housing to run 2 roller bearings. 1 kilo came off that. The valve spring retainer was re-designed to have a smaller disk shim and without machining the cam carrier used a solid tappet. More weight off the valve gear. For those who own 124 Spiders and the known ground clearance issue on the sump pan. Initially i was going to go wet sump big wing but when a pump assembly became available to me at the right price I decided to go dry sump instead.
I'm nearly there now, but still have to sort out the air box, the alternator, the dry sump tank in the car and the ECU. Can't wait now.
- Cos Spider unit.jpg (90.45 KiB) Viewed 26713 times
- Cos Spider unit (1).jpg (110.29 KiB) Viewed 26711 times
- Cos Spider unit (2).jpg (117.86 KiB) Viewed 26712 times
- Cos Spider unit (3).jpg (126.7 KiB) Viewed 26712 times
- Cos Spider aux ds mod.jpg (60.11 KiB) Viewed 26717 times
Re: Fiat spider, engine and things
Carbon fibre? That's sneaky Cos!
They'll all be after you now!
cos
Ha ha! well you have no idea the amount of effort it took to polish a standard cam cover (hands still sore), then make a glass fibre mould!
Pleased with the finish though.....
Uros Piperski
Looks great (not only the carbon fibre).
Why didn't you completely remove the aux shaft wheel and housing?
Rich Ellingham
Cos I thought mine looked good! Excellent. Have you any photos of the stages of fabrication of the cam covers from negative moulds to finishing the mating surfaces?
I guess all the pulleys are aluminium? Did you fabricate them?
Rich
Rich
book 38
cos
Uros Piperski wrote:Looks great (not only the carbon fibre).
I just though it would be easier to use the standard belt layout and length.
cos
pulleys (except the cam ones) are machined out of solid and hard anodised. Did not alter the water pump speed though.Rich Ellingham wrote:Cos I thought mine looked good! Excellent. Have you any photos of the stages of fabrication of the cam covers from negative moulds to finishing the mating surfaces?
Rich
Cos, email me the original photos would you?
I'll swap them for these, the photos uploaded here don't do justice to the level of prep.
cos
will do Guy
TR-Spider
That engine is very nice made, congratulations!
I bet the airbox will be a nice carbon thing as well...
A question on the modification of the valve tappets.
I guess your intension was to reduce mass, is it really that lighter now?
And adjusting the valves is now a camshaft-out job?
Thomas
Thomas
GC_23
cos
Hi, thanks for your comments. Yes the airbox will be carbon as well. The space available under the spider bonnet is bit restrictive though.
Regarding the tappet weight saving, yes 37g reduction per tappet (including the shim - based on average size) so total valve gear weight saving was 296g.
What do you weigh Cos?
Any savings there?!
(Mountune let you do 'homers' then??!!)
Any savings there?!
cos
my wallet has....
wildman
Re: Fiat spider, 8V engine and things
I love those valve covers.. Too bad you didnt do the distributor in the exhaust form,, I would gladly pay premium for them. It brings a new tech look to the old lump,, i love that stuff.
wildman
love to see more pics of this project..
