I found a good article on the burton power website with some good information. http://www.burtonpower.com/technical_1/ ... ystem.aspx
Showing an example race engine breather setup:
It raised a number of questions and provided some guidance also.
The article also advised that you can get excessive oil coming through the cam cover breather if located directly above the cam (to which my 8v one is an example) without some form of shield.
So on this basis, I should either fit a shield to the inside of the cam cover, or get it moved tothe end like the mi16.
Here is my existing setup (not far from the OE setup)
It now seems the cam cover is feeding excess oil back to the oil filler hose. I assume it's not venting air (or aireated oil) as otherwise it would join the oil fiiller at the top in order to vent. So my first question is what's the bloomon point of that then, as the head has oilways back to the sump?
It seems outlet in blue is the only actual breather hole; i'm assuming this because it's the only hose that joins the oil filler tower at the top. Is this correct ?
So what about these 2 proposed systems:
As you can see from both proposed solutions i'm not draining back to the sump. I have seen catch tanks that are a 2 part system, one compartment with de-arieated oil to go back to sump, and another section with vapour/water/gunk to be drained
