tmvolumex wrote:Interesting looking breather / oil separator on your new engine block. It looks to have significantly larger flow capacity compared with the units on a normally aspirated engine. This makes sense as a turbo engine will have more blowby. Do you have any additional details or photos of this separator?
About the Breather
Indeed, this breather is larger than the N/A engine version. After gas pass thru the breather it reaches another device called by Fiat as "Separator"
This device is a simple box with an wall inside. Something like this drawing shows.
- Brazilian Tempra Turbo Separator internals
- Separador.JPG (15.71 KiB) Viewed 31785 times
As oil is unable to go upside, it goes down to sump.
In the sump there is a tube for connecting the hose that comes from the Separator unit.
About the Belts
Here 8V engine uses belts with this specs:
Width - 18mm
Lenght - 1351mm
Height - 4,25 mm
Numb. teeth - 142
Tooth to tooth distance - 9,525mm
Tooth height - 1,90mm
Goodyear code - 532LH071
Dayco Code - 142s180
Gates code - 41142x18
16V engine use belts with this specs:
Width - 18mm
Lenght - 1384mm
Height - 5,40 mm
Numb. teeth - 173
Tooth to tooth distance - 8mm
Tooth height - 3,08mm
Goodyear code - 173HP8180
Dayco Code - 173SHPN180H
So they are different tooth profile.
18mm is 0.71", almost 3/4". So our belts are not the wide version.
I was wondering about belt "enlargement" yesterday. Here Marea 2.4 5 cilinders use 24mm (1") belts with the same tooth profile for the 16V 2L, but with only 168 teeth, 16V belt minus five teeth.
I don´t know if my crank pulley would be large enough to fit this Marea belt, nor if i have enough clearance for tensioner (as it has minus 5 teeth)
Just by opening the belt protective cover i will be able to check it. This weekend i´ll do this.
Case it doesn´t fit i´ll look after a solution for the belt problem.
About the tooth jump problem, that happens with the 3/4" belt, it´s worth mentioning that here in Brazil the first two year producion 16V engines suffered from this problem.
Fiat has made a change in the belt system by inserting an extra bearing along the belt longer lenght side (the side oposite to the tensioner).
At the middle of the lenght between the crank and cam pulleys.
This bearing only touchs the back of the belt. It avoids the increased vibration of the belt along this side. Fiat said this solved the problem (not really)
For the early 16V Fiat produced an adptation kit that allows an easy fit of the extra bearing.
Dispite Fiat effort in reducing belt failure, our 16V are known by been an belt eater, i guess because of the narrow belt used.
About the pistons
This new engine block came with four A class pistons alreary mounted. The four C class pistons are backup ones, case a i make some mistake (hope never to use them)
Really thanks for the help and forgive-me for any typos (i am doing my best)
Bye
