16v Head Conversion...
madmurdoch
Post by madmurdoch »
Hello all,
I have the chance of a tuned 16v head from a Tipo 16v,
And want to put in onto an 8v Tipo engine.
I know the head will fit.
But do i have to change the pistons to match??
Any help would be great Thanks...
Darren.
Testament
Post by Testament »
yes you need to change the pistons as the 16v ones have different valve cutouts.
madmurdoch
Testament wrote:yes you need to change the pistons as the 16v ones have different valve cutouts.
Thats what I thought. So its not as easy as some people make out then is it.
Thanks for your reply.
Darren
Darren, nothing easy is worth having.
sumplug
Post by sumplug »
Hi Darren.
As i told you on Sporting Fiats, its not straightforward. And unless you are going racing, stick with the 8v head. The 16v head only wins at high revs, and you need to really rev it to do that. 8v head will be more then you require if properly gas flowed and built.
Andy.
madmurdoch
Ok Andy,
It was just a long shot as i said can get a New head Cheap!!
Will have to think on the lines of Carb's, Cam's Ect..
Would the Carbs from a 130tc fit ??
Thanks Darren.
sumplug
Post by sumplug »
Yes, they will go on. This head responds very nicely to gas flowing. Just follow Guys's Head flowing technique guide.
Even an engine running a single Weber DGV 36/36 gives excellent power throughout the rev range.
Basically follow the old three 'C' rule;- Compression, Carb[s] and Cams.
Andy.
