Hello Guy
i have made a short path manifold for weber DCNF 44 carberator upgrade. It is now mounted and operational . ( Yet to be tuned ).
I note that the accelerator pump cam profile is quite different from the origional DCA 5 / 250 36 weber carb.
Question: Disregarding all other tunable componants , ie pump jets .
Would you retain the cam that came with the DCNF 44 . Or
would you transfer the DCA 5 cam on to the DCNF 44.
Note : At this stage I have no information on what vehicle the
DCNF 44 came from
Beta VX supercharged , Carb upgrade, Accelerator pump cam
keithvx
- the cam on the left is the DCNF 44 item. on the right is the origional DCA item
- gcb.JPG (143.12 KiB) Viewed 9678 times
keithvx
photos of dcnf 44 and custom manifold
thanks GC.
Manifold and carb set up , as per photos
I am having 32 chokes made and would very much appreciate any advice on jetting etc for beta vx race motor /weber DCNF 44.
regards keith
regards keith
- gca.JPG (148.53 KiB) Viewed 9669 times
- gcc.JPG (144.55 KiB) Viewed 9669 times
keithvx
Induction for DCNF
Yes induction is a challange. When running the standard carb and manifold i took the normal cold air feed from over the radiator and feed it to custom air box via ducting . Duct fed to inside of k&n filter and airbox took air from outside of filter to carb top . Box designed to sit on carb but bulk of filter housing sat to the side and fed from under box.
However this time i may feed from behind head light. iIhave moved radiator sideways and have moved power bump in bonnet to over the super charger. i will see how much height i can get before making a decision.
regards keith
ps . Gave up waiting for 32 chokes so made my own last night from a set of dellorto 32 chokes. Was not as hard as i thought. Found out in the process that although carb has 44 stamped on it , it is actually a 42 . ?
regards keith
- standard (carb / manifold /bonnet )induction for my vx beta race car
- gcd.JPG (149.12 KiB) Viewed 9648 times
