Hi, i`m Zare from Yugoslavia, and I drive Fiat punto with 1108 engine. i`m amater and i`m intrested in tuning that engine. For now I did the cam, copression rate, chip, intake... what u sufest next?
- Can u tell me where to find technical dravings of 4-1 manifold and downpipe? Or U can advice me how to build one.
- What can i get with bigger throttle body (whant to stay on SPI, and will remape it)?
Zare
F.I.R.E 1108 in Punto.
NST Club
Julian
Zare,
Could you give some indication of what you want from the engine and what you intend to use it for?
There are some ideas here:
http://www.wolfdirectracing.com/press.aspx
NST Club
Julian
A 4-1 exhaust tends to give optimal power over a narrow range while a 4-2-1 is usually configured to give a broader range of power - far more useful for rally and more likely to aid the longevity of the engine.
I don't have the dimensions you need - the exhaust you saw was bought in. We have plans to produce similar manifolds early next year in stainless steel.
