Frequency - I think - may be may be too high for a rod bearing and it is quieter when you rev up.
Check the water pump, alternator bearings and cambelt tensioner pulley.
Simon
Post by Simon »
Thanks Guy, I did suspect the water pump as that is around the area the noise is coming from, but it spins nice and smoothly by hand with no play - although that may be different when warm and under the load of the belt. Likewise the alternator, although that is on the other side of the block anyway. I suppose I should have ran it without the drive belt before I started pulling it apart! I've not checked the tensioner yet, so that is still a possibility. Either way I've committed to pull it out and rebuild it now, its long over due. Hopefully I'll get a few hours on it this evening.
GC_15
Simon
Post by Simon »
I got back from work at a reasonable time this evening so had time to get start the engine removal. I decided to first pull the head and manifolds off in one lump to keep things manageable. After that I pulled the water pump and then the bottom pulley and cam drive, and I think I have found the source of the knock/tapping. The keyway in cam belt drive looks to be damaged allowing it to move on the crank a few degrees. I had some issues in this area before, having to replace a damaged woodruff key, so must have missed the real cause. I'm not sure that the crank pulley fit is entirely correct either as it has an extra groove for driving an aftermarket AC compressor that was part of the Anniversary package. I assume that the knocking at idle was the drive hitting each side of woodruff, and the fluffiness was the resulting timing shift (potentially misfiring the injectors too which are driven from the LT side of the ignition). It may also explain why the noise disappears when being revved as the cam drive would tend to be forced to one extremity of the play.
Lifting the head assembly off. Its not some fancy reverse head installation, it twisted round once it was off the block!
Head off, I will probably pull the clock and gearbox out as one unit.
What I think is the source of the knocking.
GC_15
nice post but I think your conclusions will prove to be wrong...
Simon
Post by Simon »
Quite possibly Guy, do you think the real answer may still be in the bottom end? Hopefully, I will get that apart at the weekend.
GC_15
I'm afraid that only a thoroughgoing inspection will now tell..
the only possible cause of a knocking noise from the crank front end would be the front pulley but was visibly loose. And when that is the case usually the whole assembly comes apart and the parts 'brain' somebody in a following car on the M25 motorway, or similar...
(so to say....)
I guess we will see...
Post by PumaPhil »
Simon,
I just wanted to say I'm very impressed by the quality of your work, great stuff and great posts!
thank you, Phil G.
Simon
Post by Simon »
That's very kind of you Phil, especially given the meticulous standards you have applied to your Spider - it's superb!
I managed to get the engine out over the weekend, and strip, inspect and start some fettling on the crank and block over the last couple of evenings.
Having seen a shot similar to this in the Haynes manual of the 'box and engine coming out in one, I decided to do the same in an attempt to avoid grovelling about underneath the car again to remove the gearbox first.
It wasn't too bad a job, even single handed.
I probably should have drained the oil first, but I couldn't be bothered to mess about removing the sump guard.
Gera box removed and on to the stand ready to start the strip down.
North Carolina's (cars original home) 'sleeping policemen' had definitely taken their toll on the sump!
Sump off, and no nasty sludge which I was half expecting.
Oil pickup still intact despite the bashed sump. A few bits of gasket crud on the strainer.
Main bearing shells no too bad.
Rods and piston out. Low comp. pistons will definitely be junked, not sure about rods yet.
In terms of any evidence of the cause of the knocking, I couldn't find anything in the bottom end. All caps were still torqued and the crank measures out just above lower limit (one journal was .1 thou below). I'm sure the problem was the woodruff, pulley and cam drive - it was a mess and as far as I can tell the only thing preventing the drive moving on the crank was the friction between the pulley. This was not loose but the bore was gouged.
See the movement here:
https://vimeo.com/161391035
Some more pics coming up...
GC_15
Simon
Post by Simon »
Shots of the 'cheesey' words and damaged slot in the cam drive.
Definite step in the woodruff slot
Top edge of woodruff rounded off
Having decided the crank is serviceable after a clean up I spent the last couple of evenings performing Guy's published unplugging operation.
Flushing though the oil ways after removing the plugs.
7/16 UNC tap. I found I only needed the middle and bottoming tap, as the starting tap in my set was bottoming out on the small diameter before engaging the cutting thread.
I bit nerve wracking for fear of snapping the tap!
Threads ready for the plugs. I won't fit them until much later in the build after final cleaning and prep. and everything else has reached the required level of cleanliness.
Crank after an initial clean and journal polish. I still need to get the input shaft bearing out.
Attention turning to the block:
Block up on the bench after a session in the parts washer. Still pretty grubby but clean enough to start demurring and pulling the core plugs and remaining studs.
Big end bearings
Big end bearings
Probably going over the top, but I tidied up the rough casting lines on the webs.
Deburred.
Deburred.
That's about it for now, looks like I will need to be contacting Guy for some shiny new bits and pieces fairly soon!
GC_15
have you modified the aux driveshaft?
The fuel lobe can hit no2 rod..
Simon
Post by Simon »
No, I've not modded the aux driveshaft (I will be on this rebuild though), the engine has never been apart, other than the head being off a couple of times and I always refer to the diagram in the Haynes manual for the positioning of the aux drive and cam wheels when disturbing the belt, but I could have screwed this up! There was no evidence on the rod or driveshaft cam of interference, although this may have been obscured by oil etc. I'll take another look though. Also, the noise only started occurring when I started it up a month or so ago to dry it out after sitting out on the drive, prior to that the cam belt and wheels haven't been disturbed since March 2013. Is it really possible that the cam lobe/rod could have been close enough to interfering throughout the three years and wear and tear has as now brought them closer together?
I'll contact you in the next few days about arranging the re-bore/pistons/rings, and ordering up bearing, gaskets etc.
GC_15
Post by Piotrek125p »
Really nice car and fantastic photostory, I am a big fan of your job.
It's possible Simon, assuming that the shaft -rod clearance was a bit 'borderline' in the first place..
Have a look on no 2 rod - near the bolt head - for a 'strike mark'...
Simon
Post by Simon »
Sorry for the very belated update. Work on the Spider has been on the 'back burner' for a while whilst working on the VW (engine build and bodywork), much prepping of my Jeep for a Pyrenees trip last August, and various other activities. I've now turned my attention back to the Spider's engine with the intention of having it ready for some summer club events.
I revisited to the potential aux shaft/ No 2 rod interference problem but couldn't see any evidence of contact. But I've now modded the shaft and as per GC's recommendation to eliminate the possibility of problems in the future. For the last couple of weekends I've been finishing off the prep of a spare head ready to fit the GC race guides I've had for ages, and prepped the FI inlet plenum and manifold which I'll be retaining for this build. I've not really got time for a detailed run down of everything I've done, but here are some pictures of progress.
cleaned up head and inlet ready for porting
Hand and manifold.jpg (489.95 KiB) Viewed 79945 times
Head ports1.jpg (398.12 KiB) Viewed 79945 times
port matching 1.jpg (445.43 KiB) Viewed 79945 times
Finishing off basic plot reshaping sufficent for guides to be installed, before seat recut.
head prep2.jpg (434.51 KiB) Viewed 79945 times
Cleaning up the manifold
Inlet cleaning.jpg (408.2 KiB) Viewed 79945 times
Matching the manifold ports
Poer matching 2.jpg (400.3 KiB) Viewed 79945 times
Almost ready for valve guides
Head prep1.jpg (455.26 KiB) Viewed 79945 times
Before seat cut.jpg (393.15 KiB) Viewed 79945 times
Manifold matched
Manifold matched
Runners cleaned up
Runners cleaned up
Over the winter months I discovered a lucrative sideline in repairing vintage hifi, which has funded a small 7x14 lathe and a press. So last week I played around with turning down the crank pulley to fit a trigger wheel for the Megavolt ignition and/or Megasquirt FI to replace the LE Jetronic. I also made up a valve guide insertion tool, and a jig for the press.
Turning down crank pulley for trigger wheel
Machining pulley.jpg (337.07 KiB) Viewed 79945 times
Test fit of trigger wheel
Trigger wheel3.jpg (334.83 KiB) Viewed 79945 times
Trigger wheel1.jpg (347.86 KiB) Viewed 79945 times
Making the insertion tool.
Insert tool turning.jpg (385.6 KiB) Viewed 79945 times
Tool engages with the shoulder of the guide and also acts a depth stop
Insertion tool.jpg (374.08 KiB) Viewed 79945 times
Boring the foot of the press to accept guide insertion tool
Machining press foot.jpg (408.68 KiB) Viewed 79945 times
Insertion tool and guide in modified press foot
Insert tool2.jpg (432.88 KiB) Viewed 79945 times
Testing the alignment of press jig
Test press.jpg (405.12 KiB) Viewed 79945 times
Hopefully I'll get the guides fitted this weekend and move on to prepping the valve seats.
GC_15
Impressive Simon! Keep it up.
