What is the difference between these two engines
Håvard
Re: What is the difference between these two engines
Post by Håvard » December 16th, 2013, 5:28 pm
Abarthnorway - Remi L wrote:Hi Håvard!
Why don't You just take the heads off?
Then You will very quickly find everything You look for. Valve size, pistons/compression, and can check the cc easily. At the same time You can get a quick overview of the condition of the engines. Its a Question of 10 headbolts - 10 min max.....
Mvh - best regards
Remi(92622577)
I have disassembled the alleged Abarth engine completely, its a 2 litre, and now its getting fully restored, but what is the main difference between abarth 2.L engine and the standard 2.L im thinking cams,compression etc, so i can check for sure what type ive bought. with the castingnumber on the head I think its from the Ritmo 130TC Abarth, but we'll see
Im more than grateful for the info on the engines from you guys,
Post by Abarthnorway - Remi L » December 17th, 2013, 10:33 am
130 TC has pistons with 2mm dome 9,45:1 comp, 43.5 inlet valves with bigger port, distributor driven off inlet cam end. The 130 cams are really nothing to brag about, similar in profile to Croma/Thema.
GC_45
torkil
Post by torkil » December 31st, 2013, 11:27 pm
Hi Håvard Pic nr 1 is a Ritmo Abarth 130 2liter ,I have acouple my self ,Pic nr 2 iam not shure ,but just mesure the stroke -90 mm stroke, OVE
GC_41
