Worn Camchafts .on my 16 V. just in 3 trackdays
torkil
Hi my camchafts is worn again , I think most off the things are fitted right.
1 Oil tubes are fitted right
2 There is no coilbinding or bad springs,
3 The lift is modest 10 mm on intake outlet 9,6mm
3 The cam boxes are lubed after trailering before start
4 Good oil has been used 10-60
5 Proper warm up before going on track
6 Oil temp has peeked a few times 110 degrees a few times
7 New walve shims has been installed,
Try to sengd picks later The first atemt went havoc, to big picks i suppose , Greek heroglyffs , Yes thats my englich.OVE
- Camchafts Summer 2013 004.JPG (168.58 KiB) Viewed 107169 times
- Camchafts Summer 2013 006.JPG (160.41 KiB) Viewed 107165 times
- Camchafts Summer 2013 007.JPG (67.7 KiB) Viewed 107165 times
GC_41
Abarthnorway - Remi L
torkil
Re: Worn Camchafts .on my 16 V. just in 3 trackdays
No not yours Mr Croft ,I have to sort out the failure first , Yours coms later
GC_41
torkil
Outlet Remmi.
What do you think Remmi
1Perhaps spring tension
2 Too mutch clarance .
3 Lub problems again
The first worn out let is still the same, byt one more has showed up.
Also The inlet bilett have showed a little more worn , that one you did see last time . Only the first lobe the ,not critical
GC_41
Urbancamo
What kind of a surface treatment those cams will have? If they are just regound and they don't have surface treatments it's not good. Especially when those cams are not in the oil bath like old TC units used to have.
GC_25
Do the std camshafts have surface treatment? Usual 8V cams are 0,2-0,3 mm worn down on lift (nose), and still work reliably with no problems....never used 16V engine myself.Urbancamo wrote:What kind of a surface treatment those cams will have? If they are just regound and they don't have surface treatments it's not good. Especially when those cams are not in the oil bath like old TC units used to have.
Inlet is billet approx 10mm valve lift - exhaust std NA 16V.
No idea really.....torkil wrote:Outlet Remmi.
Maybe valve springs are not able to handle 8000+rpm....do not know how that would show up on the cam though.
Regarding the oiling it should now be the same or better than std 16v after Your mods - according to people racing the 16v they tend to eat the std cams quickly (Thema SW)
Clearance?? Do not think so...You would know:-)
Maybe fuel contaminated oil....?.... just a thought...
Remi
GC_45
torkil
Its a standard Tipo inlet but used on outlet , Treatment nothing i supposeUrbancamo wrote:What kind of a surface treatment those cams will have? If they are just regound and they don't have surface treatments it's not good. Especially when those cams are not in the oil bath like old TC units used to have.
GC_41
Use GC triple springs and all new shims Ove!
Ove showed me around his engine bay today - always a lot of fun, clever and unusual solutions everywhere:-)Guy Croft wrote:Use GC triple springs and all new shims Ove!
Probably a good idea with new springs - the impact marks on the cam seems to indicate that the valves has been "bouncing about" a little.
Remi
GC_45
torkil
Fault nr 1 from my side is ,I have slipped in an worn shim and that has done harm to one more outlet lobe,
2 Valve floot or bounce ,Jumps from the beginning off the ramp and hits the side off the top flank.
Cure after my opinion , GC tripple springs , Ove
7800.perhaps 8000 on std springs , Isent good .
GC_41
Very good Torkil.
Once again - its time for a cam change!!
See You!
Remi
See You!
Remi
GC_45
