GaryR
Simon. The Olio colour scheme does look very nice and I hope you're glad you kept that choice. You're doing a superb restoration considering the amount of room you have in your garage. The photos angles seem to make the inside space of the garage look bigger than what I saw in reality!
Well done!
Well done!
GaryR. Book #104/500
Simon
Thanks Gary. I did wonder whether the Olio Fiat scheme was a good idea or not but I'm definitely glad I went for it now and I don't think it is going to be a problem for the club road rally events I'll be having a go at - coincidentally it is also our car club's colour scheme. It should all start coming together a bit more once I get all the lamps, seals, windows etc fitted back on, plus the 'essential' set of Super Oscars. Hopefully you'll be seeing more of it out on the drive when delivering my credit card statements!
As for the camera angles, I generally use a very wide angle lens (10-17mm 'fisheye') to fit it all in, hence the curvature on some of the straight lines. Perhaps I should get a job as an estate agent ;-)
GC_15
Simon
Last weekend I spent a lot of time rummaging through the various boxes of parts I had stored away to see what was useable and what parts I am missing. I also started on making up some polycarbonate windows and grappled with the rusty window runners and mechanisms. I also did some other fettling jobs like remaking some bonnet hinges as the first set I made didn't give quite the right amount of forward motion to prevent the sides of the bonnet catching on the wings. Then there were other little jobs like rebuilding and testing the wiper motor and mechanism, and pluming in the screen washers ready to refit the scuttle panel.
I now have a week booked off work at the end of June to work on the car, so in preparation for that I been taking measurements, making lists and ordering various bits and bobs to ensure I have the necessary parts to make the most progress in the time.
GC_15
Simon
Well, the rubber seals I ordered from Woolies arrived today, together with the front indicators and headlight looms from SVC. So this evening I pressed on with things. I had a quick look at the various trims and seals and checked the fit and all seemed good, so it will mostly be a case of cutting them to length and fitting them. I am going to wait until after I have given the paintwork a final cut and polish to avoid getting compound on the rubbers. So I moved on to the front indicators. I hadn't really worked out exactly how I was going to mount these, other than deciding they would go behind the rectangular holes in the front valance. After some messing about with some cardboard templates I decided to make up some ali brackets to mount them. I only had time to finish one side, so I'll have to make the other tomorrow evening.
GC_15
Rallyroller
Hi Simon
Great work. I am in admiration of the amount of skill and effort you put into this project. Just the time spent on making well engineer brackets etc. Very impressive.
Your progress is much more rapid than mine. It is all the little jobs that take time (ie freeing off all the wiper assembly and spindles!!)
I have 4 mm polycarb for all the windows. How did you fix the quarter light in? Is it fixed or does it move? Can you see any problems with scratching of the windows when they go up and down? Are you using the original rubber seals on the window that “wipe” the glass as it goes up and down?
Keep up the good work. We must meet when you have the car on the road.
Rallyroller
Rallyroller
GC_13
Simon
Thanks RR. You're right about the 'little' jobs, it took me over an hour just to get the washer pump wiring working again.
I haven't fixed the quaterlights in yet but intend to bond them in with a polyurethane sealant bead. I junked the opening mechanism and rubber seal then made the new polyc. version to fit the outer frame very closely. So the glass area is a bit bigger overall. For ventilation I will probably fit one of those rotating ball ventilators, but I want to make sure it won't interfere with visibility through to the wing mirrors.
As for the drop glass, I am just going to use the original electric winders (not ridiculously heavy) and weather seal system, as I already have all that stuff and just want to get it all back together again now. I did buy new scraper seals from Spiderpoint as the originals were shot, and I got a length of the flocked window channel seals from Woolies. I am certain the polyc. will scratch when running past the seals but it will have to do for now. I am wondering if facing them with clear window film would avoid that problem? I did think about going for fixed glass and sliders but its an expense I could do without and they're not that practical for everyday use.
Yes, we'll definitely have to sort out a meet once one or both get back on the road. You can aways pop down to Go Motorsport Live at Silverstone where mine will be on the 7th July - probably not roadworthy by then though!
GC_15
Rallyroller
Hi Simon
Ref scratching of the polycarb, I was considering the same thing (window film. ) For me if it lasts a season then it should be ok. As the car will not be left exposed to the elements (ie it wil be in the garage when not competing, I think it should work. My worry is all the mud from stages etc getting caught in the seal. Fixed with sliders is not allowed under the rally regs for the class I am entering. ( only later cars)
I have not looked at the quarter light yet. I will try and retain it as opening as I find it a useful way to get cooling on the stages. ( Dangerous to have the window open. ) I will investigate .
RR
RR
GC_13
Simon
I always liked the opening quaterlights too on my Lada's and the Spider, they were great way of controlling ventilation without the annoying draft and noise of a partially opened window. I decided to to go for light and simple this time though with fixed 'glass' with some of those swivelling pop-out vents you can buy.
Some more pics form last weekend's activities which included several hours messing about with window mechanisms, motors and cable drums, various bits of wiring, re-felting window channels, and mocking up a sump guard. The real thing should be here next week.
GC_15
Simon
I took this week off work with the aim of getting the car to ready for the stand on the 7th July, so its been a busy few days, ordering and collecting parts and generally doing various jobs, mostly on the interior.
Here are the pics...
- Door capping and CF panel temporarily in place. The door capping will be covered in alcantara to match the dash.
- _IGP1311.jpg (331.29 KiB) Viewed 48098 times
GC_15
Simon
Thanks Will, its been a bit of a hard slog this week but its all starting to come together, although I have had to rush a few jobs just to get them done in time for next week's show.
My carbon/kevlar sump guard arrived this morning, but I ran out of welding gas so have only managed to tack the crossmember mounts and couldn't make up the front crossmember brace/mounts, but it'll be good enough for show purposes if I don't get time in the week to finish it properly. I'll post up some more details when I have it all figured out - it was originally designed for a Mini, but a bit of measuring and discussion with the supplier who offered to cut it to slightly different dimensions and it will do the job nicely. For oil changes you release the crossmember mounts and it hinges down with the front vertical section slotting nicely into the lower grill hole. It will also provide a nice mount for the front number plate.
GC_15
Simon
Four days left now until the car is due to be at Silverstone! The aclantara for the console and door cappings turned up today, as well as some aluminium mesh for the front grill. Being back at work I am now restricted to working in the evenings, but managed to get a front grill made up and fitted. I also modified the bonnet hinges into hook shape so that the bonnet is retained and hinges normally but can easily lifted off completely. I've also ordered some new number plates and appropriate Sebring wing mirrors.
GC_15
Fantastic!
This would make a great book!
I admire your skill and craftsman ship very much.
LanciaNut69
I love this car! Fantastic work, and I agree with Guy, the restoration would make a good book!!
Darren
Darren
__________
Book #435
Book #435
Simon
Thanks for the kind words Guy and Darren. It's been a fraught few days on the run up to yesterday's show at Silverstone. By Friday evening I still had tons to do to make the car presentable.
Saturday was spent zip tying up wiring, fitting the console, bolting in seats and belts, and wet sanding the boot lid and bonnet. Then machine polishing the entire car with two stages of compound. My brother then arrived so I roped him in to putting on a coat of wax whilst I finished lacquering the lower quarter panels and fuel filler flap. The night wore on fitting the quarter panels, door panel and various rubber seals. I decided that there was too much work to complete the door cappings and finally went to bed at 3.30am Sunday, but before I managed to fall asleep the alarm went off at 4.30 to get up again! Have you ever tried loading a car trailer quietly at 5am on a Sunday morning so as not to disturb the neighbours?! Anyway, it was then an easy run down Silverstone to get setup. It was a great event but blazing hot and I was too knackered to even take many pictures. Some pictures...
Next thing will be to redo some of the rushed jobs properly and get it MOT'd.
GC_15
