Oil cooler pipes length for mid-engined Alfa
FERRARIST
Have mid-engined RWD Alfa 156 2.5V6, and i have problems with oil cooler location and effectiveness.
Below is basic pictures of initial location with 19row mocal cooler, and now bigger cooler - unfortunately it can not fit on same location and i moved it just behind the engine(transversely mounted) - oil temps still too high.
Recently observed Lotus elise oil cooler location and my question is:
Is there any danger of oil pressure drop if i move the cooler just behind the front bumper - that's 2 meter pipes each direction???? I guess i must use same ID size as cooler's and sandwich plate.
Any tips on this.
Thanks.
Any tips on this.
Thanks.
- DSCF4188.jpg (69.95 KiB) Viewed 9568 times
- IMG_20130620_134205.jpg (73.44 KiB) Viewed 9568 times
fingers99
Re: Oil cooler pipes length for mid-engined Alfa
There probably is some danger. Assessing how much would require someone far more gifted than I.
You could always look at a water/oil heat exchanger. These have the advantages of not needing an oil thermostat, warming up the oil sooner, and can be placed just about anywhere that you can get water to -- hence you can run very short oil lines. They're also much more robust than air/oil heat exchangers.
The only real downside is that your (water) cooling system will be a little more stressed.
Laminova is a trade name for one type.
GC_06
Laminova - I agree.
Air-oil coolers of the type you have shown will only work (at all!) if they have a good airstream in and thru and out! You are not going to achieve this here. I have known people to use bigger and bigger ones and find even the largest they can buy will not work - a sure sign of a head-dispersant problem caused by inadequate airflow.
Call my pref supplier Think Automotive about the size of the Laminova and appropriate hose fittings tel: 020 8568 1172
The device is best placed on the return coolant line from the bottom of the radiator back to the engine to give maximum cooling effect to the oil. A thermostat is not needed.
Nobby
Have you done any experimenting with ducting and/or fans?
Chris Burgess
GC 01
GC 01
FERRARIST
No fans yet, when i used the smaller cooler, it was mounted where pictured air-scoop is, fed directly from outside air. Bigger cooler is hard to fit in same place(but not impossible)........Nobby wrote:Have you done any experimenting with ducting and/or fans?
- DSCF4684.jpg (204.07 KiB) Viewed 9537 times
please re-read what I wrote - getting the hot air away from the cooler is the problem, not getting it in!!!
Your whole engine bay is going to be at engine temperature!
FERRARIST
Yes, point already taken......few months ago my water rad was just behind the rear bumper and it did'nt work well.......Guy Croft wrote:please re-read what I wrote - getting the hot air away from the cooler is the problem, not getting it in!!!
fingers99
Looks a really interesting car: I'd love to see more photos.
GC_06
